what stall to choose ?
anti balloning ?
bolt circuit ?
pilot diameter ?
furnace brazed ?
and more ...
do i ignore those and choose 4l60e for matching ?
If the stall speed it too high like 3000 RPM the car will feel sluggish at low RPM light throttle driving. A 2800 RPM stall will not be over the engines power band it just makes city driving less enjoyable if the converter slips too much.
A 2400 stall will act like stock at low RPM and will perform better at WOT.
If the stall speed it too high like 3000 RPM the car will feel slugish at low RPM light throttle driving. A 2800 RPM stall will not be over the engines pwer band it just makes city driving less enjoyable if the converter slips too much.
Thanks man , What good brands to go with ? Summitracing has tci , b&m but no yank or vigilant
I'd stay away from TCI and B&M. TCI was my first non stock converter. I had the broken TCI replaced along with the trans that went bad.
I would go with a 2800 stall. Precision Industries Vigilante is expensive but it's the best available. For normal daily driving you can't tell the difference with a good converter. Looking back I probably could have gone with the 3200.
Please do a search and read my past posts ....
2400 b&m was fun on the street , pretty good i liked it
after a big research,everybody commented on the fantastic things a Vigilante could do
They were right , its one of the best mods ever, worth every cent !!!!
I paid like $ 1000 including shipping and i tell you,im STILL in love with it.
Its true that it might feel a big sluggish on downlow rpm ...but you never drive at 1200 rpms ...at part throttle is amazing ,WOT made my car a screamer and in Overdrive it pulls and pulls and pulls !!! Vigilante turned my 87 into another thing that i was not expecting.
They have better torque multiplication and im VERY happy with it !!!
Check this one for sale ...that price is a steal !!!
http://forums.corvetteforum.com/c4-p...converter.html
Go get it before someone does !!!
read my story here :
http://forums.corvetteforum.com/c4-t...tion-done.html
The ARCHIVES are filled with valuable information to all.
C3 included.
Spend time researching on your own for a day or 2.
I have left many valuable posts here too along with Sammy & thousands of other Corvette fanatics.
BR
I change my fluid often, on the car with the loose stall converter .
I tend to be more conservative, because too loose of a converter is like having a slipping clutch.
If you have a nitrous application, the anti balooning plate is needed.
The only reason I chime in is because i'd hate to see you spend all that time and money, and then not be happy....
Choose wisely grasshopper.....
It's a sweet buy. Probably rated for more HP than you have, but it would work fine if 2800 stall is what your looking for!!!
Good luck!
City driving differences are MINIMAL
If i had to do it all over again i would have choose the 3200 the first time
but i learned and it was a nice experience to compare both.
This is about the set up that it seems that you want. A 2400 converter will launch at about 80-100 horsepower. and a 3000 will launch at about 175 horsepower. That's your tire burning right there. A 75% improvement at launch. That IS why you will be faster in the quarter. Street driving will still be a lot of fun. When you stomp it and kick down a gear from a roll, you will have more power to the wheels because of the higher stall.
If you get a 28-3000 stall it will also allow for future mods. Did you know that a 3000 stall converter on your engine now will magically turn into a 3200-3400 if you do head work a bigger build and up your torque. It allows for future expansion.
Converters aren't magic but they are assembled using some pixie dust and the builder waves a wand over each one that leaves the factory.
Thanks a lot for the great info and the interesting dyno sheet.
someone at known performance companies advised me to go with 2600-2800 , thats what some said too
http://www.700r4l60e.com/store/catal...kup-p-124.html
I can't see the stall speed !!
Get the 3200 Vigilante and you'll be VERY HAPPY !!!
i can tell you because i have tried other stalls and brands.
It's not that im blind for the vigilante
Let us know !
