about tranny cooler.
Old Apr 24, 2002 | 06:12 PM
devilfish's Avatar
devilfish
Default about tranny cooler.
Will that help much to keep the tranny "alive" ? After my little probleme with overheating tranny that started to slip. I am going to install a big tranny cooler this weekend, to prevent that from happend again. My tranny works just fine now under "normal" driving, so I think I dont need a rebuild right now. And I am also going to install a tranny temp gauge, where do I put the censor, drill a hole in the tranny oil pan and put it there?
Best regards
//Devil
Old Apr 24, 2002 | 06:43 PM
jpee's Avatar
jpee
Default Re: about tranny cooler. (devilfish)
I have a 96 & it comes with a trans temp gauge from the factory... so I don't know the best place to mount a sensor.. however my trans used to run around 215 deg, & now with the cooler it runs around 165 deg & I have a 2800 converter..
The cooler is the best thing you can do...
Old Apr 24, 2002 | 06:50 PM
vader86's Avatar
vader86
id call around to whoever makes the tranny sensors as to where to put it, i wouldnt install that stuff myself.
Old Apr 24, 2002 | 07:40 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
i just ordered a tranny temp guage from jeg's. i have a 2800 stall converter & am installing a tranny cooler also. i was wondering the same thing (how to mount the sensor) couldnt i remove the pan...drill a hole...weld a nut for sensor & be done? has anyone done this before? :confused:
[Modified by yoslambo1@cs.com, 6:40 PM 4/24/2002]
Old Apr 25, 2002 | 04:27 AM
devilfish's Avatar
devilfish
Default Re: about tranny cooler. (yoslambo1@cs.com)
Is it a know probleme that the th700 get overheated and slipping when running at the track, or just a bit more extreme driving? Do I DARE to run my car at the track again, with my tranny cooler in place ?
And must I flush the system after i have installed the cooler, to prevent air in the system, or does it not work like that?
Regards
Old Apr 25, 2002 | 07:03 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
From what I've been told, heat kills a transmission.
I just ordered a trans cooler and temp gauge.
I don't even know what the sensor looks like, but I guess when I get it I'll figure something out.
I'm going to a 2800 stall and the converter is also smaller(in diameter) than stock.
Old Apr 25, 2002 | 07:53 AM
devilfish's Avatar
devilfish
Default Re: about tranny cooler. (Mr Mojo)
So this is a commond probleme and unik for me?
To about tranny cooler.
