'85 Electrical Issues
Old Jun 30, 2011 | 12:13 PM
TSLinSTL's Avatar
TSLinSTL
1st Gear
Default '85 Electrical Issues
Have begun work on dressing up the '85 I got from my Dad. Car runs pretty well though the interior is pretty trashed. Looking for some advice on some electrical issues I am having.
1. Turn signals. Currently on the exterior all lights work when the signal is switched left or right. When using left turn signal the interior signal light comes on solid and the exteriors do not flash. When the right turn signal is used the interior signal light does not come on but the exteriors do flash. Any ideas where to begin.
2. Tach problems. The tach display does light up on the dash. The tach sensor is NOT plugged in to the distributor. If I plug it in to the dist the car will not start, it will turn over but not start. If I plug it in while the engine is running the engine shuts down. My Dad believes this to be a faulty Tach filter. Is this likely?
I have limited tools but I do have a good Simpson multimeter. Thanks in advance for your input.
Old Jun 30, 2011 | 12:22 PM
oldalaskaman's Avatar
oldalaskaman
I vote, buy an FSM and start chasing wires.
Old Jun 30, 2011 | 03:26 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
1- Check to see if there is any corrosion in light sockets, check for good grounds and check to see if bulbs are all good.
Some info from my 86 FSM >>http://members.shaw.ca/dankai/Exterior%20Lights.pdf
2- Sounds like there is a short to ground in the wire or filter. Years ago my engine just died while driving. No spark, pulled cap to find I had pinched the tach wire between cap and base, which eventually cut through the wire and shorted to ground. Pulled it out and away I went.
Old Jun 30, 2011 | 03:35 PM
HlhnEast's Avatar
HlhnEast
I caught an engine harness one time between the bell housing and block. Have you had the engine out, replaced the clutch or tranny work where you may have pinched the tach wire there?
To '85 Electrical Issues
