Starts then dies every time
Old Jul 2, 2011 | 01:48 PM
Camocorvette79's Avatar
Camocorvette79
7th Gear
Default Starts then dies every time
I have a 1985 corvette that was running fine until one day it wouldnt start and I figured out that it was bad spark plugs. So I replaced the plugs and the wires and now it will start but then die within two seconds. Ive tried everything I can think of. I checked my TPS voltage, the MAF, the fuel pressure. Any help would be appreciated.
Old Jul 2, 2011 | 02:00 PM
Seattle C4's Avatar
Seattle C4
Vacuum Leak???
Old Jul 2, 2011 | 03:01 PM
Thomas K's Avatar
Thomas K
Have the same problem, found if I push on the connection plug of the VAT Module it starts thought I had it fixed but problem came back, I hope the connection of the wire that sends the 5 volt signal to the ecm to pulse injectors is not making contact on mine, hopfully not a circuit board problem, I'm not that good at soldering.
Old Jul 3, 2011 | 12:35 PM
Camocorvette79
7th Gear
Ok so I checked the pulse to the injectors and I'm not getting any pulse.
Old Jul 3, 2011 | 02:18 PM
Thomas K's Avatar
Thomas K
when you changed the plug wires did you accidently unplug wires from the ignition control module it sends signal to ecm to tell it when to fire the injectors
Old Jul 3, 2011 | 03:46 PM
Camocorvette79
7th Gear
I checked the ignition control mudule and it looks like everything is plugged in. Is there any way to test if that signal is being sent?
Old Jul 3, 2011 | 04:21 PM
Thomas K's Avatar
Thomas K
you can remove the module and take it to a parts store and have it tested, also did you check connections comming out side of distributer by firewall.
Old Jul 4, 2011 | 09:37 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
How did you test for pulse ?
Is the 4 pin connector at base of dizzy, clean and tight ?
Old Jul 6, 2011 | 12:32 AM
Camocorvette79
7th Gear
To test for pulse I plugged a test light into the end of the injector harness and when cranking it didn't blink at all. And I believe it is but I'm going to double check to make sure that I have good connections everywhere.
Old Jul 6, 2011 | 08:03 AM
AGENT 86's Avatar
AGENT 86
A noid light is usually used to check for pulse. I don't think a regular test light can be conclusive, although I have never tried since I have an Actron fuel injector and harness tester.
Old Jul 6, 2011 | 08:57 AM
c92vette's Avatar
c92vette
You must install a noid light (borrow one from Autozone) to check the injector pulse.
To Starts then dies every time
