Recommend a Dana 44 rebuilder.
You'd probably make money on the deal. Really 3:07 dana 44's are a very easy find. People are looking (hard) to get a dana 44's with the 3:73's cheaper than 1500 bucks.
Whole 3:07 diff is easy to buy for less than a grand. Do your homework.
And dont even suggest a dealership out here.
There just isnt a market for C4/Dana 44 etc stuff out here.
Well, I have the 3.07 gear in Hand. Now I need to look for a case.
Perhaps an experienced re-builder could offer some insight?
By the way, I believe 3:07's were the factory ratio in the 4+3 cars from 1985-1988. After that, 3:42's and 3:33's came in the ZF corvettes.
There are plenty of used 3:07's on ebay too.
HOUSING SPREADER.
SPECIAL 2 PIN ADAPTERS TO ALCOA ALUMINUM CASE TO HOUSING SPREADER.
CLUTCH PACK SERVICE TOOLS.
PINION DEPTH GAUGES.
DIAL INDICATORS THAT READ DOWN 50 MILLIONTHS OF AN INCH.
SNAP ON TORQUE WRENCHES.
1/4"
3/8"
1/2" DRIVES.
MOST IMPORTANTLY I HAVE NEARLY 25 YEARS SETTING UP REAR DIFFERENTIALS & READING, INTERPRETING DRIVE SIDE CONVEX & COAST SIDE CONCAVE GEAR TOOTH NOMECLATURE PATTERNS.
EVEN A SLIGHT DEVIATION FROM PERFECTION DOES NOT LEAVE MY 2 HANDS UNCORRECTED.
I CAN DETECT .001" TOO MUCH PINION DEPTH, TOO SHALLOW PINION DEPTH, TOO MUCH BACKLASH, TOO LITTLE RING GEAR BACKLASH BY STUDYING GEAR TOOTH CONTACT PATTERNS IN 15 SECONDS BY PERFORMING A GEAR TOOTH PATTERN TEST.
The only other person I have ever met with same rear diff gear setup experience as myself was my late friend.
He taught me.
He is gone.
Passed on.
Brian R.
I may end up just trading my D44 with 3.75 built by IKERDS to get a D44 in Very Good condition. Or, if I can find a D44 pumpkin for less than an arm and a leg, I may just swap the gears with the 3.07's I acquired today.
It took me 1 year to track them all down.
I found them all New Old Stock, never used in original packaging.
I even have the Kent Moore C4 Dana 36 & Dana 44 rear diff housing holding fixture & attaching arms.
Dana's are some of the most difficult rear differentials to set up.
All Dana model housings have super stiff cases.
Why a case spreader is almost a must for ease of disassembly & assembly.
Carrier adjustment shims are located between the tapered roller bearing cone & cast iron diff center section case.
You calculate shims incorrect.......
Remove bearings on both sides & start over.
Usually the bearings & shims get destroyed upon removal again.
Pinion depth must be set at + or - .000".
In real world , within .0001" or 1/10,000 of inch.
You can better understand why there are so few people around to set up any C4 rear diff correct the 1st time for max durability & no gear whine or howl on the street & highway speeds & while WOT racing.
Few have the ability to measure that close of a tolerance & maintain it during assembly.
Most compromise or do not care.
The end result of ignorance is wasted $$$, short service life, gear whine & howling at highway speeds that drive you insane after 5 minutes, and a very pissed off car owner & Corvette enthusiast.
They are totally insane with C4 dana 44 prices these days.
Shop around.
Watch Craig's list in your area.
Watch C4 parts for sale, where I found & bought my 1985 C4 dana 44 with batwing cover for $900 shipped to me 2 years ago.
No accident crash damage & near mint condition.
Brian
Its a pain on a C4.
Ford 9" is super easy.
I can set them up on my workbench to perfection in under 2 hours.
I can drink my cup of coffee & enjoy myself.
I am sure your Buddie would not set a C4 rear diff for free likewise.
Its hard work & have to work diligently towards perfection start to finish.
If a person does not have that hardcore attitude to begin with.......
Don't even attempt to set up a C4 Dana & claim it to last under street or high performance race use.
Happy 4th. of July to All on C4
BR
The reason I say to keep the 3:73's is also....What if you go through all the trouble to swap rearends and then don't like the 3:07's.
Then you'd have to figure it out all over. If you got a clean, low mileage 3:07, you have the option to switch it back if you were not happy with the change.....just a thought.
Good luck
Good luck
I found a couple on fleebay. I swear, people need to get realistic on the "value" of a differential.
If I run across a good deal,
I will P.M. you.
You finalize the purchase yourself.
1985- 1988 C4 dana 44's have the 1st design case.
Most plentiful on Corvette market I have found.
Still strong enough for more than 90% of street performance C4 guys & gals.
I have found them as low as $400.00 complete without batwing.
Currently I only have my 1985 C4 Dana 44 & Dana 36's too.
They are crazy on ebay yes.
Do a saved search(s) : 1984-1996 Dana 44, C4 Dana 44, Corvette Dana 44.
Something just may show up in the next month in your price range.
$2K is too much yes. lol
Brian
I will P.M. you.
Brian
They only allow 100 saved searches on ebay per account.
I love C4 Corvettes & Vintage Pontiac Muscle.
So I have all 100 spots filled 24/7/365 days a year.
Sometimes I have to wait 6 months or longer for that item or part I want or need.
Luckily C4's are easy to find parts for yet.
That C4 Dana 44 is worth more than most beater C4's running around.
Keep watching.
You will land a good deal.
Try & get the matching batwing the Dana 44 left the factory with.
Better that way.
BR
Keep watching.
Better that way.
BR
Yes, sorry I didn't know about Brian sooner too. Ikerds is good, but I would have appreciated a second (possibly better) choice, and you really seem to know your differentials!
Thanks for the info Brian, that is how us hobbyists learn.
Maybe a services link for anyone who does work related to vettes on the site would be agood idea, or i just havent seen it yet?
