L98 plenum and runner question
Old Jul 4, 2011 | 01:09 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Or just "glue" one side of the gaskets with silicone for positioning. Considering the wedge shape of the plenum, I considered that the best option.
I also considered it easier to remove the valve covers to access the bottom runner bolts. Of course, that means removing the EGR pipe which is it's on PITA.
Old Jul 5, 2011 | 08:13 AM
87vettevert's Avatar
87vettevert
Also, be sure when you set the fuel rails on top of the injectors, you don't pinch one of the o-rings. Ask me how I know.
You will spray fuel all over your engine and possibly have a fire. I was fortunate and did not have a fire, but had to go through the whole process again to replace that bad o-ring. I did go alot faster the second time though.
Just take your time and it would be a good idea to rebuild the fuel rail while it is out.
Just my thoughts
Old Jul 12, 2011 | 12:01 PM
samsonb's Avatar
samsonb
Originally Posted by WW7
Better then that , you can remove just the plenum and replace the injectors without removing the runners..Here is the PDF..This is how I did the injectors on my 89....Easy.....WW
http://mysite.verizon.net/brianjbalo...torRemoval.pdf
Did you have to pull the EGR valve when you did that method of pulling the fuel rail?
Old Jul 12, 2011 | 12:40 PM
vette079's Avatar
vette079
You will spray fuel all over your engine and possibly have a fire. I was fortunate and did not have a fire, but had to go through the whole process againd to replace that bad o-ring. I did go alot faster the second time though.
Just my thoughts
I'll be back here, just don't know when.
I've ordered the gaskets from FIC, but it will take a while for them to show up here since I've ordered several items in the US and have them shipped to a place were they put everything in a container for shipping to Sweden.
It could take a month and a half to show up here.
