L98 plenum and runner question
Old Jul 3, 2011 | 03:02 PM
vette079's Avatar
vette079
Default L98 plenum and runner question
Hey everybody, is it possible to remove the plenum and runners in one piece?
Or do I have to loosen the runners on one side to get it all out?
That way I only need to get runner to manifold gaskets when I replace the injectors.
Old Jul 3, 2011 | 03:19 PM
joe paco's Avatar
joe paco
just finished mine this week. supposedly you can remove plenum/rt runner asm, but I couldn't do it. the gasket set included all, plus TB, which I did not remove, also o rings except the two for fuel lines.
you won't save more than a few bucks.
the deal is that the runners are a bitch, they have to be rotated out to clear the valve covers. even by themselevs it is time consuming.
joe
Old Jul 3, 2011 | 03:21 PM
vette079's Avatar
vette079
joe
Where did you get the gasket set?
Old Jul 3, 2011 | 03:22 PM
WW7's Avatar
WW7
Better then that , you can remove just the plenum and replace the injectors without removing the runners..Here is the PDF..This is how I did the injectors on my 89....Easy.....WW
http://mysite.verizon.net/brianjbalo...torRemoval.pdf
Old Jul 3, 2011 | 03:47 PM
joe paco's Avatar
joe paco
vette79, gaskets came with the Bosch III's, FIC, but any parts house will have them.
have not watched the pdf to which WW7 refers, but the III's are seated in intake, then fuel rail is seated over them, bolted down.
I had heard this, and tried to see if I could make it worthwhile to do that way, decided I had plenty of time. seemed easier to remove runners.
joe
Old Jul 3, 2011 | 03:59 PM
vette079's Avatar
vette079
joe
Bought mine from FIC (been two or three years) and didn´t come with any gaskets.
Only those on top and bottom of each injector.
Been checking FIC´s new site, he has a set for 30 usd.
I guess I´ll buy that one and see if I only remove the plenum and TB or the runners as well.
I saved the PDF, just in case.
I read somewhere that when you remove the fuel pump fuse prior to dismantling the whole thing, will depressurize the fuel system.
Sounds logical, but is there a downside other than that it might take a long time for the car to start after finishing the surgery.
Old Jul 3, 2011 | 04:10 PM
joe paco's Avatar
joe paco
I wasn't clear, ordered teh gasket set.
I removed FP fuse, ran engine unitl it ran low on pressure, let sit overnight. you have to pressurize rail to check for lks, so install fuse, turn key on and off a dozen times. don't try to start.
when it is complete and batt cable has been disconnected for 10 mins, it does require about 15-20 secs to run, not sure if ecm resetting, or fuel pressure, but not an issue, just a surprise, because I "checked" schrader valve with a finger and there was fuel.
*** the Haynes manual is good for this, and I followed it pretty much. was replacing hoses to TB coolant so I removed most of the "front" but no need to rem TB.
Old Jul 3, 2011 | 04:29 PM
vette079's Avatar
vette079
Cool, thanks for the tip on pressurizing before starting.
Just ordered the gasket set from FIC.
Old Jul 3, 2011 | 05:03 PM
joe paco's Avatar
joe paco
I made ANOTHER error. pressurize after bolting in fuel rail to manifold. that's in most instructions. if you want some of my opinions, things to do and not to do, tools, etc, I can send a PM.
it is mostly wrench work, and thinking of next steps while doing so. I used a simple checklist that saved me from having to remove rail to clear out the Intake manifold temp switch.
joe
Old Jul 3, 2011 | 05:28 PM
vette079's Avatar
vette079
Sounds logical.
What's that with the air temp sensor?
Old Jul 3, 2011 | 05:46 PM
joe paco's Avatar
joe paco
Sounds logical.
the wire connector plugs in as plenum is reassembled to runners. I had captured it beneath the rail somewhere, so when I pulled it to see that it was clear, I caught it before I went too far.
also, one hard plastic vac line goes OUTSIDE the plenum, on passenger side, it and all lines under plenum need to be dressed before plenum is assembled. if so, you can plug in in a few seconds.
even if you know, take some close ups of lines and hoses routing esp in the front of engine. I forgot your year but mine was 91. of course, you can put paint dots on inj plugs, 1-6 dots, to ID those.
j
Old Jul 3, 2011 | 06:01 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
You could probably remove all runner bolts and pry the plenum/runner assm off the intake. The problem would be aligning/slipping the runners over the new gaskets. I'd think that would be VERY difficult (if not impossible).
Removing the plenum (only) is the proven way to short-cutting the process.
If you turn the key to "on" and listen, you'll hear the fuel pump (line) pressurizing. Not sure why depressurization would be an issue. It doesn't hurt the motor to rotate a few extra times before firing. In fact, the ECM programming diliberately delays firing for about 10 cycles. I coded my for 5 to make it start more like a "normal" car.
Not a bad feature though...at least it insures the oil pump has time to pressurize before ignition. (That's why I didn't change mine to no delay).
Old Jul 3, 2011 | 06:03 PM
l98tpi's Avatar
l98tpi
Max G’s
I have rmoved the complete manifold on both of my cars combined a total of 5 times. I use the factory manual if I have any questions. I think it would be very difficult to remove the injectors without removing the runners. Not saying it isn't possible, but it would be difficult to remove and replace the injectors without using some force. I don't understand why one would want to cut corners to save time and take a chance on damaging new injectors. As well, doing a complete dissasembly would allow to inspect the system. As far as where to get the gaskets, you could get them from TPIS or Chevy parts dealer. Good luck.
Old Jul 3, 2011 | 06:17 PM
joe paco's Avatar
joe paco
you forgot the fuel rails, Gregg, the asm is outboard of the plenum and captures the runners, totally. I looked at every route, but I was doing this for experience, since I am retired and the old injectors were "perfect." took my time, changed coolant lines, and it was about 8 hrs. maybe 5.5-6 hrs of work. there were no issues to be corrected -yet- after 90 miles.
was surprised that starting took longer than it ever had, but figured the ecm was doing that.
joe
Old Jul 3, 2011 | 08:09 PM
GREGGPENN's Avatar
GREGGPENN
You are right...Now that I think about it, at least one side (of the runners) would not clear the fuel rail -- while attached to the plenum.
OTOH, my post was to say not to remove them as an assembly anyway.
Old Jul 3, 2011 | 08:30 PM
WW7's Avatar
WW7
The plenum is wedge shaped for a reason, the reason being so it can be lifted straight up and removed without removing the runners.I have removed my plenum many times without ever loosening the runners, when the plenum bolts are removed the runners flare out a small amount.. Once the plenum is removed the fuel rails are unbolted and seperated before lifting them from the base ( this way they clear the runners). Using the PFD that I supplied I can replace injectors in half the time it takes if removing the runners and do just as clean a job. At least give it a try, if it doesn't work for you all you have to do then is remove the runners.....Also before bolting everything back together don't forget to pressurize the fuel system to make sure nothing leaks..Im just letting you know this procedure works, its up to you if you use it or not........Good Luck...WW
Old Jul 3, 2011 | 08:34 PM
joe paco's Avatar
joe paco
actually, neither side would clear. runners have to be rotated towards each other at top, to clear valve cover at btm. also, the inside bolt, each runner, has to be accessed with plenum off -even then the rr bolt left side intake is almost impossible to reach.
not being argumentative, just clarifying. removing plenum, then disassembling fuel rail can be accomplished, maybe, but my first time, didn't want to cause myself grief.
saludos,
joe
To L98 plenum and runner question
Old Jul 3, 2011 | 11:31 PM
Marv02's Avatar
Marv02
I had a leaking O ring one #1 Injector I pulled that Injector and out it back in with out removing the plenum and runners It was not fun but it can be done.
10 mm wrench lossen up the fuel rail and pry it up.
I just wanted ot see if it could be done.
I would not do it again.
If I was going to replace all the injectors I would pull the Plenum and runners.
The 9th injector can be a pain sometimes.
I found out when putting runners back on leave the base runners bolts LOOSE so they can move around so when you put the Plenum back on it easyer to put the plenum gaskets back on with out tearing them.
After all the Runners bolts and Plenum bolts are put in loose then tighten them.
You can get gaskets from Summit Racing either OEM Felpro sell a kit for cheep I have SLP cost a little more but the runners are larger bores.
Old Jul 4, 2011 | 04:03 AM
vette079's Avatar
vette079
Funny, I didn´t recieve an email about new replies.
Well, I´ve read them all sofar, and I ordered a set from FIC for 30 USD and I will try it the PDF way first.
If I see that the runners aren´t going to be a problem I might as well take them out also, but it seems they can be a pain to get out.
I do know that I have been tightening one of the runner to base bolts once, three years ago, that was somewhere around the 6-8 cylinder.
Old Jul 4, 2011 | 07:57 AM
joe paco's Avatar
joe paco
I read the pdf some time ago. the guy knows his business, like so many on this forum. I would try that first.
the WORST part is the btm bolts on the runners, because you can't get the #40 Trx on them, UNLESS you asemble the right tool for it.
one tip: I used invisible tape to tape all gaskets at their top, close to bolt holes -even over one hole- to keep them in location during the wiggling part of reassembly. no way the tape would cause a vac leak, since it's only. 0015" thick. of course, keep the gaskets lying flat.
' it's as easy as you let it be,' so my dad used to say.
saludos, joe
** if you get any questions, sent a PM or post.
