Steering Column fix (Tilt)
Old Jul 5, 2011 | 11:07 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Steering Column fix (Tilt)
I know I read it somewhere.
What company sells the replacement housing for the tilt issue suffered on the 90-up cars?
I think I might just get a new housing for the 90 but I forgot where I saw it
Old Jul 5, 2011 | 11:22 AM
Gear Jammer's Avatar
Gear Jammer
Active Streak: 90 Days
Probably this thread:
http://forums.corvetteforum.com/c4-t...pictorial.html
My source for NOS housings was corvettesteering.com
Last post in the referenced thread makes mention that you can get oversized pins. Definitely cheaper, but I would surmise they would only work if yours isnt too far gone.
Old Jul 5, 2011 | 09:05 PM
-=Jeff=-'s Avatar
-=Jeff=-
yeah that is it. is there a way to get to the pins without complete removal?
Does Corvette Steering offer the oversized pins
Old Jul 5, 2011 | 09:55 PM
Gear Jammer
dont know about the oversized pins. I didnt know about them when I rebuilt my column.
I read somewhere (here maybe) that you can simply lower the column (without disassembling anything) by removing the two bolts under the knee bolster. The electrical cables and whatnot should have enough slack to allow the column to lower enough to clear the lower dash, allowing access to the pins. Note: I never used this method, and I dont know how you could compensate for the tilt-counterbalance spring - its fairly stiff. In other words, if you removed one of the pins with the spring still under tension, it might force the housings out of alignment to the point you wont be able to get the pin back in. Mebbe somebody else will chime in.
Old Jul 6, 2011 | 12:27 AM
C4Callum's Avatar
C4Callum
I fixed the play in my column recently by repairing the housings rather than buying new ones. I'm a machinest so for me this was a far cheaper option. You can get the pins out with the column still in the car by undoing the two upper bolts. On my car replacing the pins with larger ones wouldnt have worked though and I'm assuming most cars would be the same. The bores the pins sit in were oval not round causing the play. The play wasn't caused by wear but rather the housings were stretched giving them there oval shape. (this would make sense as you dont often change the tilt)
Because of this im not sure if hammering in larger pins would have pulled every thing back into place.
I bored the pin holes out and Inserted bushes the same size as the pins.
This took the play out and so far has been fine.
Also you can remove the spring with the column in place. I just pulled the pins out when I did mine though. It doesnt move that far forward.
I don't think I have explained this very well so if you have any questions feel free to ask.
Old Jul 6, 2011 | 08:44 AM
-=Jeff=-'s Avatar
-=Jeff=-
Thanks Guys
Gear Jammer,
do you have PN for the parts I need to order if I do the replacement like you did?
Also what did it cost?
thanks
Old Jul 6, 2011 | 09:18 AM
Gear Jammer
Jeff,
heres the breakdown:
Corvette Steering: NOS tilt housings, $310. Dont have a PN handy, but he'll surely know what you're talking about when you call. In my case, I got both the upper and lower housings. I think he only sells the pair anyway. In my case, the pins themselves were ok. The alumimum housing doesnt wear down the steel pins. But I gotta tell ya, for the price of new pins (~$10), I wished I replaced mine, just for the peace of mind. One of those "might as well since Im here" kinda of things.
Bottom bearing spring retainer (GM 7847029) $7 - got one off of ebay. Optional, as I broke this when removing it. My car had two anyway. odd
Loctite 609 - ~$20. Can get this fairly rare (and expensive) breed of Locktite at any reputable machine supply store. Fastenal has it I know.
good luck,
John
Old Jul 6, 2011 | 09:53 AM
-=Jeff=-'s Avatar
-=Jeff=-
Thanks John,
I am thinking I need to rebuild mine for piece of mind as well
One last thing, was yours a 90? if so how did you keep the clock spring for the Air bag from spinning too much, heard that is something that needs to be watched when removing the wheel
Old Jul 6, 2011 | 12:21 PM
Gear Jammer
Mines a 91. The clock spring is no big deal, as long as you dont fiddle with it. You would have to go out of your way to get it out of whack.
Old Jul 6, 2011 | 09:19 PM
WVZR-1's Avatar
WVZR-1
The bushing is certainly a better approach and there's many choices of materials. There's two diameters on the pins, did you use 4 bushings? A bushing repair I would think is a "once and done"!!
Old Jul 7, 2011 | 12:52 AM
C4Callum's Avatar
C4Callum
Yeah I rebushed all 4 bores. I used Teflon coated steel bushes I brought from a store which worked mint. Personally I'm not 100% convinced it will last forever but if I get another 20 years out if it I will be happy.
Old Dec 20, 2011 | 04:45 PM
Cavi's Avatar
Cavi
so what is the consensus, if I am replacing the housings, do I need to remove the colulmn or can I do it while it is in the car?
Old Dec 20, 2011 | 05:27 PM
Gear Jammer
To replace the housings, the steering shaft has to be removed from the column. According to the FSM, removing the steering shaft requires removing the column assembly from the vehicle. In this case, I believe them. It would be almost impossible to remove the shaft while the column is in the car. Definitely easier to work on once it is removed from the car.
Old Dec 20, 2011 | 07:55 PM
Moonlk's Avatar
Moonlk
When I did my 93 last winter I took a dremel to the housing and ground enough material out of the middle so that it could be removed over the shaft without removing it. Also had to do the same thing to the new housing but i think there is no loss of strength in the area where the material is removed.. Saved a lot of work I think.
Old Dec 20, 2011 | 11:18 PM
93VettePilot's Avatar
93VettePilot
The steering column comes out of the car in about 30 minutes and makes working in the column so much easier.
Old Dec 21, 2011 | 01:31 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
My tilt mechanism completely failed
Since some of the switches (wiper) we shot as well
I'm replacing the entire column with a used one $300
Vs rebuilding the old one $1200
To Steering Column fix (Tilt)
