Cat question for those in the know?
Old Jul 5, 2011 | 02:37 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Default Cat question for those in the know?
I have an 87. I'd like to run cats. I'd like to not have to run an air pump with all it's hoses and junk. Can it be done and get the cats to light off?
Old Jul 5, 2011 | 02:51 PM
383vett's Avatar
383vett
Yes, just remove the pump, reroute the belt, and plug the ports.
Old Jul 5, 2011 | 02:55 PM
87bob's Avatar
87bob
Will the Cat light off and kill the noxious ordor that way?
Old Jul 5, 2011 | 04:13 PM
383vett's Avatar
383vett
Yup. The air pump only injects air after startup when the motor is cold.
Old Jul 5, 2011 | 08:58 PM
vader86's Avatar
vader86
Yep, just yank it all off.
Old Jul 6, 2011 | 02:24 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Are you sure? I thought it went from exhaust manifold injection during warm-up to cat injection after that. Of course, there's a third option of venting (exhaust) air but I can't remember when that occurs...during EGR operation maybe?
I thought I understood the cycle back when I removed my AIR setup but it's obvious air is pumped both the manifoldl and to the convertors for at least some period of time...and not at the same time either.
In both cases, I'm assuming it speeds up the operation of the converters. Without the AIR system, I don't believe I've seen documentation on how much delay is present but I'm convinced the converters still work within a reasonably short delay after the stock config. (I could see what the FSM says about operation if you're really curious.)
Another possibility presented by this forum is the AIR pump "dilutes" emissions by increasing the percentage of air to carbon. And, as Dave pointed out in a recent thread on E15, that's NOT a realistic way of reducing emissions. It's a cheap parlor trick.
Old Jul 6, 2011 | 07:51 AM
vader86's Avatar
vader86
Yes, its in the manifolds on startup to light the precats, then only the main cat.
Old Jul 6, 2011 | 08:45 AM
87bob's Avatar
87bob
Hi Vader,
Thanks for the reply. But my issue is the main Cat. I never had precats since I owned the car. I fear the main is not lighting off. When ever I had somone behind me they siad the fumes we enough to knock them out. I was hoping to be able to eliminate the air pup and the line running to it by running a different type of cat. I know much has changed since this car was designed and I do want to be green (and legal).
87Bob
Old Jul 6, 2011 | 08:57 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Random Tech cat has been a popular choice.
Old Jul 6, 2011 | 11:54 AM
GREGGPENN's Avatar
GREGGPENN
Originally Posted by 87bob
Hi Vader,
87Bob
You're afraid the main cat is not "lighting off" even with your AIR tube still attached?
There is a possibility your car has another issue. Mine started to smell bad when one/two injectors lost their integrity. When injectors "fail", they can throw the O2 sensor off. When at least one injector is weak on the O2 side (driver's side), all the other injectors will be instructed (by the ECM) to add more fuel. By adding more fuel, the ECM thinks it's correcting a lean condition for all cylinders (vs a lean condition on just one cylinder).
If this happens, you'd actually be running rich. If two (or more) injectors are bad on your DS bank, the result could smell awful. That's because the PS bank will be very, very rich.
FWIW: The only evidence I've seen on the main cat's ability to "light off" w/o an add'l air supply is based on anecdotal evidence saying someone passed emissions w/o that tube. IMO, that doesn't mean the cat doesn't perform better with it. I'm fairly certain emissions are based on a percentage compliance based on the year of the vehicle. That means the older the vehicle, the more it can pollute and still pass.
Old Jul 6, 2011 | 02:37 PM
87bob's Avatar
87bob
Shoot anything is possible. The car is all apart and I'm in the process of putting a T-56 in it right now.
To Cat question for those in the know?
