93 ignition module , HOT !!!!!!!!!!!!!
Old Jul 12, 2011 | 10:56 PM
barney10mm's Avatar
barney10mm
Default 93 ignition module , HOT !!!!!!!!!!!!!
car starts cold , module gets hot fast then wont start , i take mod out , put in frezer 5 mins , put back in vet . starts up . its a new mod . why is it getting so hot >???????????
Old Jul 13, 2011 | 12:23 AM
jfb's Avatar
jfb
It might be defective. They normally get warm, but not hot!
Old Jul 13, 2011 | 12:39 AM
Repzard's Avatar
Repzard
What Brand ?
I know of people having good luck with the Autozone Duralast brand.
Also my want to do a search on the Coil Module MOD using washers or even moving its location off head.
Havent had to replace my 93's yet but replaced everything else around it
But did clean it and used good CPU heat sink compound for computer processors
BTW..Its called Artic Silver , has a small amount of aluminum in it.Better heat transfer to heat sink.
Old Jul 13, 2011 | 08:32 AM
1963SS's Avatar
1963SS
This is a good time for someone to check the spacer/air gap cooler theory. As mentioned, put a few washers between the heatsink and the head. See if that makes a difference. Inquiring minds need to know. Since the transistor in the module acts as a switch and not a regulator there shouldn't be that much heat generated. Warm yes but hot....no.
Old Jul 13, 2011 | 08:58 AM
barney10mm's Avatar
barney10mm
its a brand new eclin , fried 3 of them . i dont have it mounted .the silver part is like a fry pan after 1 min of runin . iv changed out everything else . thank you
Old Jul 13, 2011 | 10:17 AM
1963SS's Avatar
1963SS
The most common thing that could cause this is a partially shorted coil. (Not enough resistance on the primary side or secondary side.) I think the resistance is around .3 ohms maybe on the primary and about 8500 ohms on the secondary.
From the high voltage coil wire to the pink wire might be around 8500 ohms and from the pink wire to the dark green wire about .3-.4 ohms. Check at the coil with the coil disconnected.
Good luck
Old Jul 13, 2011 | 10:45 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Answered in your other post - it has to have the thermal paste and connected to the heat sink or you fry it.
I have a couple of washers between the head and the ICM/Coil assembly. It helps some, parts still get real hot but if I put a fan over it while in the pits it cools down much quicker.
Old Jul 13, 2011 | 06:43 PM
barney10mm's Avatar
barney10mm
if it has washers and its not touchin head ...... whats the point ?
Old Jul 13, 2011 | 06:54 PM
1963SS's Avatar
1963SS
Hey Barney, the post that said you were unable to touch it after 1 minute of running is the biggest symptom. It really does sound like something shorted on the secondary. I have mine on a custom heatsink but I can touch it just fine after running it hard for 30 minutes. Since you've changed three of them it may be time for a coil. There isn't really anything else in that circuit.
Old Jul 13, 2011 | 09:32 PM
barney10mm's Avatar
barney10mm
i changed coil .... but the only part that is hottttttttttttttt is the shinny medal part . i mounted it to heat sink . not as hot now but still no start after warm up .
Old Jul 14, 2011 | 12:43 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Check the wiring - use the FSM troubleshooting procedure.
Old Jul 14, 2011 | 09:47 PM
Repzard's Avatar
Repzard
Just to shoot a idea at you about how you use a fan to cool in pits.
Maybe you can mount a computer or GPU fan on a switch or temp sensor where fan kick on at certain temp like wiring it into cooling fans
also use it if your in traffic as well as racing.
If I was to do a mod like this for racing I would move the module off head and relocate it ,get rid of stock heat sink and use a copper cpu heat sink and mount on firewall or a high spot up front.
Stay nice a cool that way
Why GM put it on the head I dont know ,but you can add it to the many flaws the LT1 is born with
Old Jul 15, 2011 | 12:20 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
There are a bunch of wires that need to be extended to make the relocation work.
Its on the head so the wires can be fairly short, including the high voltage coil wire.
With the new harness from the opti to the connector on the intake I don't have the heat problems on mine any more. Everything still gets pretty warm, just not so warm it craps out on me.
To 93 ignition module , HOT !!!!!!!!!!!!!
