I have a HPPIII on the way to reset the speedo after gear install and while I'm waiting I've changed out the thermostat to a 160 degree. What temps should I program the fans to come on and off? Also can I turn off the CAGS with the HPPIII? Thanks.
Just disconnect the CAGS. I used two rubber caps to protect the connections. If it throws a code stick a 2.2k ohms resistor (5/$1 Radio Shack) in the male connection.
jrw, I have the HPP programming set to bring the primary fan on at about 182 (IIRC) and the secondary fan on at about 193 on my 94 and I have the 160 degree T-stat as well. Of course I am currently dealing with figuring out if I have an intake manifold or head gasket leak as well :confused: (what the heck, I have 107,000 miles on my 94):smash: . - Denney
Already have CAGS disconnect hooked up but would prefer to reconnect amphenols and turn CAGS off with programmer. Can it be accomplished with the HPPIII?
