MAF delete
Old Jul 15, 2011 | 06:53 PM
LD85's Avatar
LD85
Default MAF delete
Since I'm going to Speed Density or Alpha N with the 2.0 XFI, there will be no need for the MAF ,, whoo hoo
I'm wondering what everyone did for the MAF delete, ,,, what did you use to replace the deleted MAF sensor?
Any pics?
Old Jul 15, 2011 | 07:07 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
90-91 air intake, Cone on the TB, SLP claw. Those are the ones I've seen the most.
You can probably use LT intake pieces too.
Old Jul 15, 2011 | 08:32 PM
VanSpeed's Avatar
VanSpeed
I used a later model C4 air duct, the ones without a MAF. I think it is something like 89 thru 93 not for sure. Then I made my own air box kind of like a C5/C6. See picture below.
Brian
Old Jul 15, 2011 | 09:30 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Brian
Old Jul 15, 2011 | 09:33 PM
vader86's Avatar
vader86
I would probably start with the later L98/LT1 intake and modify from there til it fit, or if time wasnt pressing, I'd get some hose material to fab one up from scratch, and connect it to a custom airbox like he did above.
I'd make sure its a cold air box.
Old Jul 16, 2011 | 07:23 AM
LD85's Avatar
LD85
Making a box like the one above would be easy enough,,
but I have the AO engineering Forced Air,,, I guess I need to figure out how to modify it
Old Jul 16, 2011 | 04:18 PM
ultraviolet70's Avatar
ultraviolet70
I have a 90-91 air duct accordian like pictured above if you're interested.
Old Jul 16, 2011 | 05:18 PM
LD85's Avatar
LD85
Would if the lower part that mates to the 90-91 lower cleaner would fit on an 85?
Is the radiator angle similar?
Old Jul 16, 2011 | 07:09 PM
yedister's Avatar
yedister
I also have AO engineering Forced Air, I used an old MAF took out all the guts and just put back in place,
Old Jul 16, 2011 | 07:14 PM
LD85's Avatar
LD85
That's the most simple solution,, after all of the AO Eng install hacking,, I hate to dump it.
Old Jul 16, 2011 | 08:55 PM
VanSpeed's Avatar
VanSpeed
Before I made my own air box (pictured above) I borrowed a friend’s late C4 air box to see if it would work in my 1985. I did not fit because of the different radiator shroud due to the different positioning (angle) of the radiators in the different years of the C4.
Brian
To MAF delete
