Looks like sometimes you have to go backwards to go forwards. Looks like Chevy copied this intake for all there LS series Motors.They just are ashamed to admit it. With the copy of this intake, they are able to get 550 horse, so those that say TPI don't flow, just don't know.
Uh, I think I see the problems. First, the engine needs to be rotated 90 degrees counterclockwise. It's installed sideways. There's no way to couple it to your tranny without the driveshaft sticking out the drivers front fender well. . Second the intake air is either on the back of the engine or the serpentine belt is on the back. If it's the belt....well then, someone put the crank in backwards. Everyone knows that the air has got to come in the front of the engine to get a ram effect. Think of the power they could make if they did it right. I may be old school but I'm just sayin'...........!
I wanna know who the heck keeps a Gen 1 3.8L and keeps the engine compartment detailed, it is nice you take care of it, but don't expect it to be worth squat. Yes, those 3.8L V6's run forever, just change the oil, forever and ever. One of the best engines GM ever made, probably only second to the Small Block in longevity.
They are all "tuned" to take advantage of certain "characteristics". The early TPI was designed to take advantage of Lower RPM torque. LT1 short runners were used to take advantage of Higher RPM. The LS series from what I understand is kind of an "in-between".
All ports are "tuned" to a specific purpose - if not matched up to the intended purpose and engine internals there is sub-par performance.
My BMW X5 actually has a butterfly valve in the intake that essentially lenghtens the runners at low RPM and closes to shorten the runners at high RPM - to get the best of both worlds. It also uses Variable Valve Timing to help this process.
Seems like the car is never going to die....from what I've heard, 3.8's will run well into the 200's
those 3.8L are pretty much bullet proof. had one in my 88 le sabre. as a matter of fact, the whole drive train was pretty bullet proof. for the first 100K miles, about the only thing that was replaced was the alternator. another V6 i've had good luck with is the 4.3L.
A couple years back I bought a 2002 Silverado with the 4.3 for a trash and yard stuff hauler. It has 253,700 miles on it. Fires up right away every time, uses no oil and runs as smooth as silk, leaks no fluids. Hope my L98 does as well.
C4 of Year Winner (appearance mods) 2019
From 4/2/2009...
I did the runners, Arizona Speed& Marine $425, Edelbrock base $350 ported it and ported plenum.I had a built motor.I ended up with crap for horsepower and torque.If you go that route you will be disappointed.
Yes I did.I bought a ported set of SLP runners and PLenum.The runners are opened up quit a bit.I followed the design that they are using on the third gen forum.They are getting 400 horse to the wheels on a 350 motor.They have to keep TPI because of California smog rules.As was stated by another forum member all intakes are tuned.In the LS series GM found that the perfect runner length is 12 inches.I just wish some company would make the LS TPI intake for our vettes.As for my First TPI build the reason I didn't get the horse power out was because I never got the proper tune.
Reason: add info
