Vette Wont Start
Old Apr 26, 2002 | 08:47 AM
kingvet's Avatar
kingvet
Default Vette Wont Start
I have a 96 LT-4 with 38,000 miles on it and I went out after work yesterday and it would not start. It just kept cranking but it wouldnt start. The battery was fine and I've had the opti replaced. Anyone have any similar experiences or ideas? :(
Old Apr 26, 2002 | 08:56 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Default Re: Vette Wont Start (kingvet)
I have had two instances of this in my 92. Both times the answer was to remove the key clean it real well, insert a Q-tip in the ignition and twist it to clean off the contacts. Hope this will help you.
Old Apr 26, 2002 | 09:20 AM
ZR_TO_ENA's Avatar
ZR_TO_ENA
Default Re: Vette Wont Start (PTz-92-LT1)
If it is cranking but not starting I don't think that it is the alarm. In my case was the fuel pump. Did you check if there is any fuel pressure? Did you check the fuses?
Good Luck
--John
Old Apr 26, 2002 | 09:22 AM
ZylaRace's Avatar
ZylaRace
Is the VATS engauged, or do you not have spark or fuel?
Old Apr 26, 2002 | 09:26 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Vette Wont Start (ZylaRace)
Doubt it's fuel related on a '96, it could be like what happened to my '95.
Everybody said change the fuel filter and fuel pump. But I was smelling gasoline, so I knew the pump and filter were fine.
My problem was ignition related and sounds similar to what you're having.
The ignition wire from the coil was rubbing against the water pump. It finally wore through so it was grounding out.
Check that before you start blindly throwing parts at it.
Old Apr 26, 2002 | 11:55 AM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
First, it isn't VATS.. the starter wouldn't even turn if that was engaged.
It isn't getting either fuel or spark. I'm leaning toward the spark too. Check your coil to opti wire, re-seat it. Check the position sensor on the opti, make sure it is connected and all. Check for codes too.
I guess this is an obvious question, but are you sure you have enough fuel in the tank?
To Vette Wont Start
