1994 C4 Trouble Codes
Old Jul 19, 2011 | 10:47 PM
jressling's Avatar
jressling
8th Gear
Default 1994 C4 Trouble Codes
I bought a 1994 C4 corvette LT1 about 3 weeks ago. As I was fixing the radio I discovered that 3 bulbs were pulled out of the center console. ASR service, ABS service, and the airbag light.
When you first turn on the car the airbag light flashes, I think 3 times, and then remains sold the whole time.
I did some research on the forum and pulled all the codes. However I am not able to find what the definitions for each code are in the A category. Please help. I do know the horn button does not work as well but the horns do.... The are bags are both in tacked.
Here are the codes:
Corvette Trouble codes: C=current H=history (old)
1.0 C12 -Starter Relay
9.0 H23 -RF Wheel Speed Sensor Open/Shorted
A C42 -
C51 -
H42 -
H51 -
H61 -
I am a college student studying mechanical engineering, so I know a little of the technical lingo. Thank you for any help. Oh and I don't have the manuals.
Old Jul 20, 2011 | 10:31 PM
pcolt94's Avatar
pcolt94
H12 is not a code, it is basically a indication the CCM is working and communicating.
Out of town, be back in a few days to give you the "A" module codes if no one else jumps in.
Old Jul 20, 2011 | 10:42 PM
jressling's Avatar
jressling
8th Gear
Thank you. Are you talking about C12 instead of the H12?
Old Jul 21, 2011 | 02:29 AM
jressling's Avatar
jressling
8th Gear
Also I got my A/C to work, however it only blows on the feet and window defroster area. I researched on the forum and they said that the vents direction is controlled by a vacuum pump that is also connected to the engines vacuum lines. Where is this vacuum pump located and where are the locations I should check for vacuum leaks. Please provide pics if possible. Thanks everybody.
Old Jul 21, 2011 | 10:31 AM
pcolt94's Avatar
pcolt94
Yes it was a type-O, should be C12.
It is not a pump, it is a 3 hose check valve under the plastic cover on the right side of the engine. Small in size, look for cracks and breakage on it.
Old Jul 22, 2011 | 04:20 PM
jressling's Avatar
jressling
8th Gear
Default Broken Valve
It was broken off. Thank you for that. You just saved me from sweating my butt off the rest of the Texas summer.
Old Jul 23, 2011 | 10:14 PM
Vette2100's Avatar
Vette2100
A code 42 is electronic spark timing 51 isProm/Eeprom error, 61 idk, i have a book with all codes and that doesnt show at all
Old Jul 24, 2011 | 12:23 AM
jressling's Avatar
jressling
8th Gear
What could cause the 42 code? Bad spark plugs or is it more of the spark plug wires?
What is Prom/Eeprom? Where is it? Sorry. I am use to german vehicles and I don't know Chevrolet acronyms.
Old Jul 24, 2011 | 05:23 AM
navy_vette's Avatar
navy_vette
PROM/EEPROM stand for Programmable Read Only Memory and Electronically Erasable Programmable Read Only Memory. It's what controls your motor in the Engine Control Module. 52 and 51 are more than likely related. I'm guessing that a cylinder isn't firing completely, the timing is off, or the ECM thinks the timing is off.
Old Jul 24, 2011 | 06:29 AM
Vette2100's Avatar
Vette2100
Code 42, is either the ignition module or the ecm, plus check the wiring and connections between the two.I would start with the ignition module first
Old Jul 2, 2013 | 04:23 PM
jdwilliams69's Avatar
jdwilliams69
Navigator
Default 1994 vett stalling
sorry, first time at something like this so I don't know what I'm doing. vett seems to stall once warmed to normal operating temps. using a jumper from 4 to 12 I get codes c12, h16, h33, h36, and h42. also get them with the scan tool but that seems to work kind of fishy. got this car last year took it and a trip to Texas from Nebraska and back ran great started it up a few time on nice days during winter for drive never in bad weather. spring drive 50 miles and died like key shout off. hard time starting back up made it back home no problems. now don't leave town with it. Still doing the same thing if it don't start I leave it for a while will start back up like nothing wrong and make it home. have checked in dark for sparks nothing, battery volts is 14.1,map sensor volts 1.13,mass air flow 11gr/sec, this stalling seems to happen at a temp around 200-210ish. also sometimes when dies with key not touched noises from under hood like fuel injectors clicking, air pump going on and off and something between firewall makes noises. thinking maybe PCM or optispark but I not sure and don't have cash to guess on elimination. any help please
Old Jul 2, 2013 | 05:04 PM
STL94LT1's Avatar
STL94LT1
H16 and H36 are optispark/distributor (H)istory codes, also dying/restarting are symptoms of a dying opti.
Old Jul 2, 2013 | 07:31 PM
jdwilliams69
Navigator
optispark could be throwing these other codes? and where and what brand would be good one to purchase. have u ever done this looks like a tight spot to get balancer off not much room this might be over my head, but cash is an issue so I better learn. will the opti sometime just quit altogether? car has 74,000 and don't look like its ever been replaced. thanks
To 1994 C4 Trouble Codes
