Vapor Lock??
I have had the car for 12 years with no problem until today. I have always had the TB bypass. The only change was made several months ago; Ported intake and heads, 32# injectors. Car has run strong with no problems. Today in Tn. it is humid and high 90's on the temperature. After a short stop of 5 minutes, the engine would not hit. Turned the engine over a half dozen times, a few seconds at a time with no firing. I let sit 20 minutes and it fired right up. Ran fine on interstate until driving through several lights in town. It stumbled after leaving a traffic light and then died on the road. After a short rest of 10 minutes it fired right up and drove 30 miles on the interstate home. No codes set, no stumbling once running again. Did the engine heat cure the vapor lock?
If you were in the Dakota's where it's usually 80 and now it's 100 that could be a problem for the gas in that area but you're in Tennessee. You're used to winning football games (Go Orange) and high temperatures. Too bad Tennessee doesn't have a basketball team. (UK all the way)
It's highly doubtful that you have vapor lock this late into the season. Since it doesn't seem to be a problem with the Vette's maybe you should check for any codes that may help in determining the cause of the car stopping. Nothing is more frustrating than not knowing if your car will get you home or not. Although your problem sounds exactly like vapor lock I think the problem lies elsewhere.
Good luck and check those codes.
There are no voids, no place for cooling contraction to make voids, and no place for fuel to go in any hurry. It bleeds down naturally and very slowly back thru the return line. The pump has a check valve to prevent rapid back flow.
I've seen TPI fuel try to boil in the steel line next to the passenger side exhaust manifold, but it did not present a real problem because as long as the fuel system was in acceptable condition the pressure prevented it from being a problem...that fuel line does need to be looked at to be sure that its clamped down and NOT riding on the header or collector. The mounting bolt nut at the bottom of the a/c evap falls apart and the fuel line flops around...
Whats probably happening in your case is a dirty fuel filter. After a run the pressure and flow force the crud in the filter. After it sits for a while the pressure bleeds off and the crud backs out and floats out. It starts again and this cycle repeats until it is so plugged up that it cannot flow anymore. A simple fuel pressure check will indicate the need to investigate further.
You may also want to look at the coolant temp sensor. Faulty temps make for hard starting under some conditions. (hot)
My 928 was vapor locking badly and I am lucky enough to live in a refinery town. A good friend of mine worked at the product application lab. After one irritating episode and getting a ride home in a VW Bug, I drove the Porsche down to the lab just to see what was going on.
They pulled fuel out of my car and after some serious chemical testing their answer was, "Well, you caught us". There was still the winter blend of about 15% butane in the gas and it can and did boil in the lines causing a higher pressure than the pump could overcome. It was in the Late winter and the Reid vapor pressure was still set for cold weather but we had temps in the 80's.
I didn't see how it could happen either but when you drive a 928 and get some hillbilly in a Bug offering you a ride home well............you know. Kinda like driving a new Z06 and it keeps stalling and some guy giving you a ride home in an Aveo. Irritated me, it did and I was going to find out why or whoop somebody's butt.
Where did you fill last? Some fuel stations, especially in rural areas do not sell much high octane fuel and still have a winter blend in their storage tanks. If so, you will have such problems in hot weather.
Thanks guys.
fuel pump check valve, injector or pulse modulator leaking. GM Pinch test should narrow it down to which one.If pulse modulator, you can replace it with a couple inches of fuel injector hose (submersible grade) and a couple small hose clamps to connect the sending unit feed directly to the pump.
Thanks to all. There was a great deal of quality input on my problem from all of you and I greatly appreciate it.
