93 Automatic trans. adjustment
Old Jul 20, 2011 | 10:14 PM
bub777's Avatar
bub777
Default 93 Automatic trans. adjustment
Just had my transmission rebuilt. Installed, and now wont go into park. How do i adjust this? Thanks.
Old Jul 21, 2011 | 07:04 PM
87 vette 81 big girl's Avatar
The auto trans shifter cable adjustment is done at the transmission shifter selector shaft underneath your Vette.
Loosen the lock bolt with a 9/16" wrench.
Put the trans in PARK manually from underneath the vehicle.
Put the shifter into PARK then.
Tighten the Lock Nut adjustment from underneath.
Recheck all gear selector positions from the driver's seat.
You may need to readjust to Reach Low 1 gear.
Recheck again & verify the trans goes Positive into Park & Low 1 every time with a test drive around town.
Brian
