6 Speed CAGS
Old Apr 26, 2002 | 02:48 PM
Jstockton's Avatar
Jstockton
FedEx Bowl 4 St. Jude '09
St. Jude Donor '09-'10-'11-'12-'13-'14
Default 6 Speed CAGS
Qucik Question about the CAGS system, The car is pretty much original with 106,000 miles. I have not unhooked the CAGS but I am considering it. When the light comes on and you do not notice it in time, I try to shift but cannot pull the gear shift from first gear, I usually end up doing a little grinding... Is this normal, I was under the impression it would allow you to shift into fourth but I cannot even get mine out of 1st gear if the light is on.
Old Apr 26, 2002 | 03:17 PM
TravisD's Avatar
TravisD
Default Re: 6 Speed CAGS (Jstockton)
Suggest getting the clutch cylinders checked out. Sounds to me like the clutch may need to be bled or you have a leaking cylinder that's causing it to not-quite release completely.
Sure you're pusing the pedal all the way to the floor as well? It's easy not to..
Old Apr 26, 2002 | 03:33 PM
Jstockton's Avatar
Jstockton
Default Re: 6 Speed CAGS (TravisD)
I do not usually go all the way to the floor, This could be part of it. Also I am thinking I am starting to have some sort of clutch/tranny problems. I had previously read in the forum everyone was changing the fluid in the 6-speed, I also have noticed they sell a Filter and gasket for some 4+3’s overdrive units but I am assuming this is not the case for a 94? Would changing the manual trans fluid help this out, Also there is no noticeable leaks under the car. So could it need to be bleed if no work has been done to the car or it is not leaking? Basically is this routine maintenance?
Thanks for your help
Old Apr 26, 2002 | 03:49 PM
vader86's Avatar
vader86
i would disable the CAGS
Old Apr 26, 2002 | 04:54 PM
rocketfinger's Avatar
rocketfinger
There is a post in the archives that indicates that although GM has no recommended fluid change interval for the ZF6, the manfacturer recommends changing it something like every 30k. Got to admit there's a big difference between 30k and NEVER. Being that GM is in the service business, too, I decided to change mine. What came out was definitely not the 5w30 stuff GM specs, in the 10k since I put the right stuff in, shifts have become smoother, there's less gear whine, and the shift lever doesn't get at all warm even after hours of driving (used to be warm to the touch). Guys who work theirs hard change it once a year, I'm planning on following that regimen.
Regarding CAGS, getting rid of it may be the best approach, I've learned to work around it and I like that it makes friends/relatives/girlfriend hesitant to drive it. On mine, if you are at all tentative about the shift, it'll bounce off the 2nd gear gate and ding 1st. A forceful pull puts it in 4th every time. Try blipping the throttle out of first, it should drop right into 2nd.
Old Apr 27, 2002 | 02:23 AM
BlackRocket's Avatar
BlackRocket
The CAGS "Skip-Shift" kit is only a two-piece dust cover. I'd just disconnect the plug and run it around the block to see how you like it. (Don't make the mistake I made by trying to disconnect the plug on top of the transmission. The plug is almost on the bottom of the tranny!). If you like it disconnected, like most do, order the kit!!! Problem solved! :D
Old Apr 27, 2002 | 08:08 PM
Secondvet's Avatar
Secondvet
Mine did not want to come out of first either regardless of whether i depressed it fully or not, rather embarrasing at times. Disconnected CAGS, have not missed a shift since. :yesnod:
Old Apr 27, 2002 | 11:38 PM
jimbomill's Avatar
jimbomill
I picked up my first Vette back in November. The first in a long line of "best advice" I got was to disconnect the CAGS.
Old Apr 29, 2002 | 01:39 PM
TealBlueEyes's Avatar
TealBlueEyes
Sounds like I'm in a similar boat - '94 6-speed with CAGS still connected. Actually, I intend on axing it as soon as I get a chance. With regard to your concerns, I'd say they sound normal. CAGS sucks to begin with, but the first year I owned the car I was convinced it didn't even work as advertised (same probs as you). My advice is if you want to shift with it when it engages, you need to pull diagonally to 4th directly. The normal shift pattern doesn't apply when CAGS engages (can't go to neutral). That seems to work. ...or put in the clutch in and hit the throttle to make the light go out and shift where you want to.
Jim
Old Apr 29, 2002 | 02:12 PM
Jstockton's Avatar
Jstockton
I have played with the car all weekend after alot of people left me advice. And I must say thanks for all the help. I found that when the light comes on and I push the clutch all the way to the floor and i must stress all the way to the floor then pull fimly out of first the selector pops over into to fourth, kinda a diaganal pull. I was doing two things wrong before, not going all the way to the floor and not pulling hard enough on the gear shift causing the selector to pop back into first and grind the gears Ouch!!
Thanks for all your help I was thinking I was going crazy
To 6 Speed CAGS
