Coolant change question
Old Apr 26, 2002 | 03:28 PM
Kevin McGrade's Avatar
Kevin McGrade
Default Coolant change question
I was thinking of doing a coolant change this weekend. Is it a simple procedure for a idiot like me?
I guess all I would do is drain the old stuff from the radiator and put new stuff in....right
Old Apr 26, 2002 | 03:35 PM
scorp508's Avatar
scorp508
Sure, if you don't feel the need to flush it completely. You'll get 90% of the old stuff out. Careful of that opti. :)
Drain...
Refill...
Run...
Add more...
Run...
Add more...
Run...
Add more...
Run... :)
Old Apr 26, 2002 | 03:55 PM
Wheelman's Avatar
Wheelman
Default Re: Coolant change question (Kevin McGrade)
you can buy the kit that hooks to your water hose to flush it completely for about 5 bucks at the autoparts store.
Old Apr 26, 2002 | 03:56 PM
JonM's Avatar
JonM
The joys of not having an opti to worry about...I usually remove the Tstat housing and the Tstat stick a hose inside and let it run for an hour or so. :yesnod:
To Coolant change question
