How to check compression?
Old Apr 26, 2002 | 07:01 PM
MDC9966's Avatar
MDC9966
Default How to check compression?
I've never done this, but I'm not going to be able to rule it out till I do. So where do I start? Will the leaking valve guides show up with this test? If so, I guess I need to fix that first to tell if I'm losing the compression? Right?
Thanks guys.
Old Apr 26, 2002 | 07:32 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: How to check compression? (Curtis629)
Check out my response to your earlier question.
It will detect leaking valves but not valve seals.
Like i said Sears sells a nice unit with a good set of instructions.
Old Apr 26, 2002 | 07:35 PM
MDC9966's Avatar
MDC9966
Default Re: How to check compression? (65Z01)
Thanks,
That's exactly what I needed.
To How to check compression?
