GM Weatherpack Connector For MAP Sensor
Old Apr 27, 2002 | 05:25 AM
gpagaduan's Avatar
gpagaduan
Default GM Weatherpack Connector For MAP Sensor
I know I can probably get one from the dealer for a couple extra bucks, but is this available at a regular parts store like AutoZone or PepBoys. I picked up one that looked like it was correct. It will fit perfectly as a replacement throttle position sensor connector but it wont mate correctly to the MAP sensor because of the way the connector is slotted. I just need the housing of the connector, not the full pigtail. Kinda weird how almost every retained clip on the connectors are broken.
Old Apr 27, 2002 | 06:37 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: GM Weatherpack Connector For MAP Sensor (gpagaduan)
Give a call to Contemporary Corvette (link on my site). They have new and used parts.
Some connectors seem to get more heat soaked than others; no matter how carefully I try the retainers break.
Old Apr 27, 2002 | 09:26 AM
JonM's Avatar
JonM
I have found PepBoys has the best selection...ask the guy to look up the # for you ....then look on the racks
Old Apr 27, 2002 | 02:49 PM
gpagaduan's Avatar
gpagaduan
Thanks Jon. I took a second look around at PepBoys at found the connector. Came with the pigtail, which I didn't need but I picked it up. I just needed the housing, which for the TPS connector was only a couple of bucks. With the pigtail was $10!! They have a really great selection of GM connectors. I wish they had the option of just getting the housing though. :D
Old Apr 27, 2002 | 03:01 PM
JonM's Avatar
JonM
Now that you have the Extra TPS connector you can make a tool (jumper) to check the voltage on your TPS :D
Old Apr 27, 2002 | 10:09 PM
gpagaduan's Avatar
gpagaduan
Default Re: GM Weatherpack Connector For MAP Sensor (JonM)
Actually, I did something really stupid. I replaced the TPS connector because it the clip was broken on it as well. The stupid thing is that I didn't pay attention to the order of how the wires were housed. I referenced my Chilton manual and when I started up the car, I got the Service Engine light and the engine stalls when I give a little throttle. You think the Chilton manual is wrong? I'm going out to buy the little tool so I can pull the code. Or maybe it's a vacuum leak? I can't tell. I've only recently started working on my car and I can't tell a vacuum leak hiss from normal engine noise at this point. ARGHHH!!!
Old Apr 27, 2002 | 11:21 PM
No Go's Avatar
No Go
I believe Ecklers sells just the housings. I tried GM and they will sell it including the pigtail and nothing else for lots of money.
I need to get an alternator connector too now:(
Old Apr 28, 2002 | 02:14 AM
Kevin 88's Avatar
Kevin 88
MAP sensor wiring:
Pin A black wih pink stripe
Pin B light green
Pin C gray
from the 1991 GM service manual.
To GM Weatherpack Connector For MAP Sensor
