1986 corvette A/C vacuum
Old Jul 30, 2011 | 01:05 AM
lespaul4563's Avatar
lespaul4563
Default 1986 corvette A/C vacuum
Can anyone show me pictures on where this vacuum hose is in the engine bay? Please.
Old Jul 30, 2011 | 03:33 AM
vetteoz's Avatar
vetteoz
The vac line runs from one of the ports on the plenum (rear RHS ) to a one way valve by dist.
Rear port of valve joins to a plastic line( very brittle and easily broken ) that is in the wiring harness on firewall and goes inside to HVAC controls.
Side port has a rubber line T'ing off to cruise control and continues along wheel well to vac ball under drv side headlight.
Old Jul 30, 2011 | 08:05 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You can see the vac line in this pic, ignore the circled part.
Center of firewall, behind the pink dist wire.
Connects to Tee in Rod's pic.
http://members.shaw.ca/dankai/Engine%20Bay.jpg
You may also find these useful, from my 86 FSM.
http://members.shaw.ca/dankai/HVAV'S.pdf
http://members.shaw.ca/dankai/HVAC%20Electrical.pdf
Old Jul 30, 2011 | 08:26 PM
lespaul4563
I checked the hose at the circular tank and I have suction and I check at cruise and I have suction, but my cruise doesn't work and neither does the a/c door. I'm so confused. Sorry for my lack of intelligence. I'm 16.
Old Jul 30, 2011 | 10:51 PM
lespaul4563
And it keeps dying.
To 1986 corvette A/C vacuum
