Underdrive pulleys
Old Apr 27, 2002 | 02:05 PM
tarheelracer's Avatar
tarheelracer
Default Underdrive pulleys
Are underdrive pulleys worth the money. And do the low speeds on the accessories cause them to run poorly?
Old Apr 27, 2002 | 03:43 PM
Vic'89's Avatar
Vic'89
Default Re: Underdrive pulleys (tarheelracer)
On my car, I have the underdrive crank pulley only. It helped performance.
But, at an idle with the headlights on , my voltage drops. The interior lights go slightly dim.
Vic
Old Apr 27, 2002 | 03:56 PM
BlackRocket's Avatar
BlackRocket
I was running the March brand of performance pully's on my '91. The kit comes with a smaller alternator pully to compensate for the smaller crank pully. Installation of the crank puly is a little trying, but you can fit a long socket extension between the pully lip and the crossmember. I had to find another size belt which required 3-4 trips to the auto-parts store to find one that fits; (Dayco 910K6). The performance increase was quite noticible "off the line" like an increase in torque. One of the best mods for very little cost. :yesnod:
Old Apr 27, 2002 | 06:00 PM
BRIAN93Z28's Avatar
BRIAN93Z28
Default Re: Underdrive pulleys (BlackRocket)
I think there are better mods out there. If you really want to do this, it is optimal to overdrive the alternater with an overdrive pulley for the alternater. Like someone else said at idle your voltage will drop and the lights can go dim because your underdriving the crank pulley. If you have or are planning any kind of stereo system in your vette be sure to over drive the alternater.
brian
Old Apr 27, 2002 | 08:36 PM
GRX's Avatar
GRX
To compensate for the idle undervoltage, you could have the eProm reprogrammed for a higher idle. Instead of 700rpm, maybe a comfortable 950rpm? ...just an idea... :cheers:
Old Apr 28, 2002 | 12:24 AM
tarheelracer
Default Re: Underdrive pulleys (GRX)
Thanks for the info, that's all I need. Sounds like a winner. I'm gonna order them tomorrow.
Old Apr 28, 2002 | 02:56 AM
Tim06's Avatar
Tim06
I may get the underdrive crank pully, how do I over drive the alternator?
Old Apr 28, 2002 | 09:39 AM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
Not worth the $$$.....seen the results on a Dynojet. :( Apply your $$$ elsewhere. :yesnod: :cheers:
Old Apr 28, 2002 | 10:57 AM
Dryseals's Avatar
Dryseals
Under drives are a waste of money. Think of it from the standpoint of what they are claiming and what really happens. Take the water pump for instance, its designed for a certian flow at a certian RPM to remove X amount of heat from the motor(granted there is a big plus or minus here). If you start to turn it slower it will pump less coolant. The thermostat is still going to open enough to cool the engine, hence you are still pumping the same amount of coolant. Some folks will say that its no longer deadheading, well with the bypasses and it being centifugal pump, the HP gain is minimal. How about the altenator?? If you slow it down, it has to work harder to keep the same charge going, the regulator will want to up the field voltage, wheres the gain?
Old Apr 28, 2002 | 11:16 AM
PhilPolaski's Avatar
PhilPolaski
Default Re: Underdrive pulleys (Dryseals)
Wait till you install a lumpy cam and TB! Then bump the idle speed up. The new version March pullies (going back a few years alt. and crank) works fine on my 85 at idle. Idle ~ 600-650 ;-)
Phil
To Underdrive pulleys
