When you get all the old accesories off, check the area around the front passenger side head. There should be a stamped set of #s, they should match the vin.
When you get all the old accessories off, check the area around the front passenger side head. There should be a stamped set of #s, they should match the vin.
- in addition, there should be another alpha-numeric stamping. it would have information on the assembly plant, final manufacturing date of the engine, and a lettered suffix code. for 82 it would be ZBA: 350ci, 200hp auto, ZBN: 350ci, 200hp auto, CE, ZBC: 350ci, 200hp, auto, CE, early production.
