No Sound with Bose?
Old Jul 31, 2011 | 11:10 PM
indy500ss's Avatar
indy500ss
Cruising
Default No Sound with Bose?
so the Radio goes on and off, Ant goes up and down, all functions work fine...but no sound?
when the radio is on, you here a clicking sound in the backround?
Old Jul 31, 2011 | 11:24 PM
l98tpi's Avatar
l98tpi
Max G’s
Unless your car is an extremely low mile C4, you would be better off replacing the BOSE sysem with something different. The BOSE is expensive to maintain. This is my opinion, it is your car. If you want to keep the BOSE, if non of the speakers work, it is probably the deck itself. Good luck.
Old Aug 1, 2011 | 09:30 AM
pcolt94's Avatar
pcolt94
You have several posts going but no year of car in any of them. It makes a big difference as the C4 spans over 10 years and there are big differences between all of them.
My generic answer is the speaker boxes are probably not the problem. The Bose relay is probably not bad since the antenna goes up. That leaves the radio head and tuner.
Does the CD or tape player work?
Without knowing the year, I can't get more specific and say anything for a fact.
Old Aug 1, 2011 | 10:05 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
There is only one relay for amplifier and antenna operation? Somehow I thought at least some years might have two (separate) relays.
Old Aug 1, 2011 | 04:53 PM
tazdpc's Avatar
tazdpc
When I did a complete removal of the I/P and HVAC and put it back together, the speakers did not work for me. (This was a winter/cold garage project) From what I read, it was due to the speaker amp relay. I ordered a new speaker amp relay and the speakers worked. Then when I started to drive the car and turned the car off with the radio still on, the speakers would make a sound that matched the blinking security light in the DIC when the doors were opened. The next winter, I looked into this and tried the old relay. It worked again. Then put the new relay in and started to drive the car in the spring until one time the battery went dead and heard some crackling sound behind the I/P. I finally put the original speaker amp relay back in and it has been working fine.
Old Aug 1, 2011 | 06:05 PM
nickpe's Avatar
nickpe
check the fuse for your door locks and dome lights. on my 85 the amp is tied to this circut
To No Sound with Bose?
