1994 c4 front wheel bearing issue??
Hi every one I drove my car the other day and heard a loud squeaking noise from my drivers side wheel I jacked up the car and attempted to move the wheel 12 oclock to 6 oclock position and then 9 to 3 oclock position no movement. I took the wheel and brake caliber off and spun around the rotor and then heard the loud squeaking noise again. I sprayed it down with WD 40 and the noise went away. Does this mean that I fixed the problem or is this a sign of a wheel bearing issue.
bearing. My wife's 2004 had a noisy rear bearing and did not show any play. Replaced it and noise is gone.
On my 92 I replaced all 4 wheel bearings at 120K miles, only the passenger rear was exhibiting any wobble. When I took it off it came out in two pieces.
