headlight relay for 1985 corvette
Old Aug 1, 2011 | 11:11 PM
professorX's Avatar
professorX
Default headlight relay for 1985 corvette
Hi guys I hope someone can help I am running into problems with locating the relays for my headlight problem, I used a DVOM to determine that I am not getting power to my right side headlight motor and was thinking it was the headlight relays but I can't find the damb things I was reading that they are located in the driver side front wheel well but I could only find the door actulator control module if anyone can supply some pics of where they are it would be greatly apreceaited.
Old Aug 1, 2011 | 11:22 PM
87 vette 81 big girl's Avatar
The headlight relay box is located on the driver's side forward lower wheel well.
If you found the horn, look back on the lower wheel well in the same vicinity.
Its mounted vertical there.
About 6 inches in length,
about 4 inches wide.
Black plastic cover on it.
Brian
Old Aug 2, 2011 | 12:23 AM
rodj's Avatar
rodj
Originally Posted by professorX
I could only find the door actulator control module .
Pull the cover , there are three relays inside
To headlight relay for 1985 corvette
