Air Conditioner
Old Aug 3, 2011 | 08:18 PM
BobRR3's Avatar
BobRR3
Default Air Conditioner
Red 1996
Air not working. Final check was to jump pressure switch. When i do this, The AC clutch ingage. So, It's either the Pressure Switch or, Low R134. Two Questions...
1: What is th eeasiest way to check the switch
2: If i need to change the switch, will i lost R134 anyway ?
Old Aug 4, 2011 | 10:54 PM
93Rubie's Avatar
93Rubie
I would see if there is any R134a in the system first. Yes, if you remove the switch any refrigerant will escape the system. I do NOT suggest this. If you have a leak find it and fix it. You may need to recharge with some a/c dye in the system too and then use a black light and some yellow glasses to find the leak. You will need access to an A/C machine to do this the right way. Can be done "back yard" mechanic style, but I do NOT recommend. The EPA will NOT approve....
Old Aug 5, 2011 | 03:46 AM
Cliff Harris's Avatar
Cliff Harris
I replaced one of my A/C switches without losing any freon. I don't remember the details, but I believe there's a Schrader valve in the fitting that the switch screws into.
Old Aug 5, 2011 | 09:11 AM
Wildride's Avatar
Wildride
Cruise-In II Veteran
!. Check for codes:
http://www.corvetteactioncenter.com/...agnostic+Codes
2. The computer may need to be reset. Disconnect the battery for 30 seconds or more-then reconnect.
Old Aug 5, 2011 | 01:26 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Originally Posted by Wildride
!. Check for codes:
Thanks good info. I didnt know about this.
Old Aug 5, 2011 | 04:43 PM
mfi's Avatar
mfi
Always nice to have some gauges on there to see what kind of pressure you have in the system...
Old Aug 5, 2011 | 04:55 PM
Muffin's Avatar
Muffin
Been awhile but I think Cliff is correct
When you jump the switch does the compressor engage and the system cool? If so freon should be OK. If not then freon is most likely gone. If so I would go the dye route.
To Air Conditioner
