Thanks! I guess that it's just a small diverter hose to the heater, and most of the coolant goes into the engine then back to the radiator over and over again, right?
Home depot parts are under the hood now. Temp gauge looks normal. No leaks so far. Hot air not blowing anymore. Fingers crossed. Need to take a longer drive to really test, then I can forget about it.
Of course, it's been 95degrees+ and muggy here for 3 weeks, and today it finally cooled off to 85. Not like Jax, though.
I think you're right. When I get the AC fixed, I'll take the inline valve out, and get the system back in order, including the blend door. Meanwhile, hope I'm good to go.
