dim dash cluster
Old Aug 3, 2011 | 09:13 PM
papasong1's Avatar
papasong1
2nd Gear
Default dim dash cluster
how to fix dim dash cluster,not the backlight,,,the leds are dim. 91 vette.thank you jfb
Old Aug 3, 2011 | 09:21 PM
jfb's Avatar
jfb
Determine if all 4 backlight lamps are on, you probably have some that are burned out. Turn your headlight switch counterclockwise to brighten. In the future, include what year vette you are asking help for.
Old Aug 3, 2011 | 11:32 PM
Shrubf4's Avatar
Shrubf4
I've got the same problem are your gauges working correctly?
Old Aug 4, 2011 | 08:35 AM
papasong1's Avatar
papasong1
2nd Gear
guages work but tach don't work and leds are real dim can hardly read them.(speedo-fuel guage and info)
To dim dash cluster
