95 stock alignment specs
Old Aug 6, 2011 | 07:06 PM
Overboost's Avatar
Overboost
From: Flint Michigan, #2 in unemployment, #3 in Violent crimes
Default 95 stock alignment specs
let me start by saying I tried the search function, I could not find specs for an alignment...
before alignment, car drove good, had a slight pull to the right
after, it still has slight pull to right, so tire is probly worn, but now steering is sloppy feeling.
all the little boxes are in the green but that dont mean squat I know.
what should my specs be to make it track tight? all they changed was the toe so I am going to guess thats what will have to be adjusted.
thank you all for your input.
Old Aug 7, 2011 | 11:16 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Here are the alignment specs you are looking for.
File Type: pdf
Old Aug 7, 2011 | 11:37 AM
Overboost's Avatar
Overboost
Excellent, exactly what I needed, thank you ever so much...
Old Aug 7, 2011 | 12:29 PM
Joe C's Avatar
Joe C
??? - not doubting what you have, but... i just had my 96 (base) aligned friday, and the specs given were:
front(r/l)camber: 0.0 to 1.0 degrees
front(r/l)caster: 5.5 to 6.5 degrees
front(r/l)toe: -0.10 to 0.10 degrees
front cross camber: -0.5 to 0.5 degrees
front cross caster: -0.7 to 0.7 degrees
front total toe: -0.20 to 0.20 degrees
rear(l/r)camber: -0.5 to 0.5 degrees
rear(l/r)toe: -0.10 to 0.10 degrees
rear total toe: -0.20 to 0.20 degrees
rear thrust angle: -0.10 to 0.10 degrees
my alignment was done on a newer hunter machine, and the specs were given as a 94-96 corvette. one thing i find odd about the .pdf file is, for a C4. they list toe in fractional inches. i'm no alignment/suspension expert, but i just find it odd, especially in this day of lasers and computers, to list any alignment spec in fractional inches - ???
Old Aug 7, 2011 | 01:09 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I've always seen in given in inches.
easier to set at the track
Old Aug 7, 2011 | 02:14 PM
Joe C's Avatar
Joe C
not disputing anything here, i just find it odd, and as i said - i'm no expert. if a spec is given in inches, say 1/32" where is the measurement taken from - an imaginary centerline of the car, and at what point on the tire/wheel assembly? ...and what is used for measuring that dimension - a 8' tape measure - ??? - remember 1/32" = .03125 - someone must have some pretty damn good eyes. in most cases, alignments are done in a shop, on a rack, and i'm guessing that's where the OP is coming from...
Old Aug 7, 2011 | 04:31 PM
BrianCunningham
They bring special tools and do it in the pits
Old Aug 7, 2011 | 05:59 PM
93Rubie's Avatar
93Rubie
These are not STOCK specs. the stock specs. are designed to minimize steering wander and dartiness. For the country club set. They also tend to wear out the outside edge of your tires a lot.
You want better wear and handling, go with the VBP specs. I did and it drives fine no wander or dartiness that I notice. Turn in is sharper and the car feels more responsive.
Old Aug 8, 2011 | 12:04 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
http://forums.corvetteforum.com/c4-t...alignment.html
http://forums.corvetteforum.com/c4-g...alignment.html
Old Aug 8, 2011 | 08:36 AM
HlhnEast's Avatar
HlhnEast
Dont know where the guy got his specs but I had mine done by a heavy duty truck place recommended by my Corvette mechanic. No lasers there, everything done on a manual machine. The guy took about 3 hours and did an amazing job. Beautiful even tire wear and on a non rutted smooth road it keeps an arrow straight path. Everything isnt lasers and computers.
Old Aug 8, 2011 | 09:35 AM
Joe C's Avatar
Joe C
i'll tell you where i got my specs - THE 1996 FACTORY SERVICE MANUAL - page 3A-6 and 3A-7. i don't track my corvette, so the factory street settings are OK with me. i figure GM knows more about alignment and suspension than i do... , not everything is lasers and computers, and the fact you had your alignment done on a manual machine at a truck shop - well, if that's good for you, that's OK with me. the topic of this thread is "95 stock alignment specs". i listed the factory specs - i felt it was useful information that answered the OP question. some seem to put a negative spin on my replies, without adding any useful information. all i said was i found it odd to see an alignment spec in fractional inches. so, what specs did the truck shop alignment your car to? it doesn't matter if it was a "state of the art" laser/computer machine or some "old school" manual rig, what matters is what were the specs that the alignment was done to, and the final results.
Old Aug 8, 2011 | 10:51 AM
mashinter's Avatar
mashinter
The tool used to measure toe is a trammel bar. It is a rigid bar that sits on the ground and has pointers that reach up to the height of the center of the wheel. You scribe a line on the tires all the way around, set the bar pointers at the scribed lines behind the tires, move it to the front of the tires, and there is a gauge on the trammel bar that reads toe in inches when you move the pointers to the scribed lines on the front of the tires. Toe (total) is the difference between the front and the rear centerline of the tires.
If the manufacturer of the vehicle publishes toe in inches it can be set manually. Hunter converts it to degrees for their machines.
Old Aug 8, 2011 | 12:16 PM
PLRX's Avatar
PLRX
2017 C4 of Year
I use the daily driver specs on my BFG KDW since 2007 and I have 100% even wear on all tires.
The GM specs suck!
Old Aug 8, 2011 | 01:00 PM
Joe C's Avatar
Joe C
The GM specs suck!
aside from toe, which is in fractional inches, and i don't know the equivalent degree spec, the BFG KDW street specs differ little from the GM specs. i see the the street camber is zero with no tolerance - WTF! front caster is within 1/2 degree of the GM spec. i doubt if you could tell the difference in 1/2 degree or two vehicles - one by GM, and one by BFG KDW specs. ??? it's your opinion, ands no flames but i'm guessing some people will bitch anything GM. your specs fail to list any total toe, cross camber and caster, thrust angle, etc. IMHO, partial alignment specifications SUCK too!
i really need to quit hanging around this thread...
Old Aug 8, 2011 | 08:58 PM
93Rubie's Avatar
93Rubie
Total Toe should be less than max. stock spec, rule of thumb on cross camber and caster is within .5 degrees of one another, .25 degrees for cross camber is preferable, Thrust angle as close to zero as possible.
I aligned my Corvette myself using VBP's specs, you do not need complete specs. unless you are using SAI, included angle, etc...for a alignment/suspension related diagnosis.
FYI, for SLA suspensions:
Caster
1/8"=1 degree
1/16"=1/2 degree
1/32"=1/4 degree
1/8"=1/2 degree
1/16"=1/4 degree
1/32"=1/8 degree
To 95 stock alignment specs
