end link bushing install help.
Old Aug 7, 2011 | 05:05 AM
93sandiego's Avatar
93sandiego
Default end link bushing install help.
I have a 93 corvette and my end link bushing were shot so i bought a set of energy suspension poly bushings. The problem is i cant fit them in the holes where the rubber bushings were. Any ideas?
Old Aug 7, 2011 | 05:51 AM
navy_vette's Avatar
navy_vette
Rubber mallet what you can into the ring then use a bench vice. You can get tons of torque from a bench vice and it makes it easier. I have heard of some people rubbing the ring and the bushing with a simple oil to help it along. I've also heard of people using Crisco, but that seems a little........ strange.
Old Aug 7, 2011 | 08:31 AM
69mako's Avatar
69mako
Two things I'v used to lube the bushing.
1.Dish soap and water...makes it slick as dog snot
2.Crisco...works well
I then put the parts into a vise to press the bushing into the hole....A large C-clamp will work well also
Finish up the process with a nice cold beer
Old Aug 7, 2011 | 09:39 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I lube the bushing edge and the link with the supplied lube. Take a 13/16 12 point socket with 1/2 in drive, put a 3 1/2 or 4 inch 3/8 bolt along with a flat washer through the socket coming from the drive side so the socket will let the bushing go into it a you draw it through. Take another flat washer and a 3/8 nut, once you get everything snugged up, square the bushing against the link then just tighten the nut the bushing will go right through nice & straight. I tried a vice and a c clamp and the bushing kept wanting to squirm off to one side when tightening, this way it will go straight through. Do the sway bar the same way coming from the inner side with the bolt & socket, you may have to pull the sway bar away from the chassis so the bolt will go in with the socket but not a big deal. One thing I forgot, remove the metal sleeves from the old bushings, they are not needed.
Old Aug 7, 2011 | 11:58 AM
93sandiego's Avatar
93sandiego
How do you remove the metal sleave? Those things feel like they are welded in
Old Aug 7, 2011 | 12:49 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Do you mean the sleeve in the control arm? That one is a PITA. There are a number of threads on that topic, with a variety of suggestions.
Old Aug 7, 2011 | 06:27 PM
Midnight 85
You may have to use a chisel to get one side bent inward, once it is bent inward it will come out with a few good raps.
Old Aug 7, 2011 | 07:27 PM
littlesk8cracker's Avatar
littlesk8cracker
ya that metal sleeve is a PITA! i used a small hacksaw blade and cut a staight line down it. once you go through the sleeve, its easy to bang out. did the same for the sleeves on my batwing
Old Aug 8, 2011 | 12:25 AM
93sandiego's Avatar
93sandiego
well i got them. i used a hacksaw and a hand held impackt end that is cone shaped to get the lower one out that one was hard. the upper one was easy to get out. and the upper bushing was easy to install also. Thanks everybody.
To end link bushing install help.
