C4 supercharger problem advise needed
Old Apr 28, 2002 | 01:48 PM
Dennis McDougle's Avatar
Dennis McDougle
Default C4 supercharger problem advise needed
I completed a Vortech supercharger install this winter and have been drivivg about 3 weeks . I set it up on a dyno and have not pushed it real hard untill yesterday. I was on the freeway at about 70 and I jumped on it. she went to 85 in a beat then she stumbled as if out of gas or lost spark three quick times in a row(almost a stall) I backed right out. This was at wot, if I bring it in at a constant increase I dont seem to have this problem but I have only been to 130mph. It happened once before when I was at a lower speed an jumped her. Thanks
Old Apr 28, 2002 | 01:52 PM
Dennis McDougle
Default Re: C4 supercharger problem advise needed (Dennis McDougle)
one point to add it does have the t-rex fuel pump(supplied with kit) added in line to the stock intank fuel pump
Old Apr 28, 2002 | 02:29 PM
8388's Avatar
8388
St. Jude Donor '14
What was your fuel level at ? on all my TT cars and supercharged cars if you don't have at least 1/2 tank of gas, the foreward momentum starves the fuel pump. If that's not the problem, then hook up a fuel pressure gage, and tape it to your windshield and see what the fuel pressure is doing when the hesitation is present. I doubt its electrical.
Old Apr 28, 2002 | 03:12 PM
lead foot 85 vet's Avatar
lead foot 85 vet
Default Re: C4 supercharger problem advise needed (8388)
Dennis sorry I can't help as I'm installing a procharger on my 85, but i'm interested in this post an want to know who did your dyno, I live in logan and am looking for a tuner. thanks
P.S. with your present situation would you recomend them
Old Apr 28, 2002 | 05:58 PM
bill mcdonald's Avatar
bill mcdonald
8388, do you know of a solution for this? My N/A 90 does this in turns with half a tank. I am looking to supercharge it and need to solve this problem. I was told that some autocross guys put another small tank in the fuel line somewhere, and it solved it, I dont see how though... maybe with another pump after that.
I was thinking about having a sump welded in and going woth an external pump. I just dont want to remove the fuel tank and rear bumper.
[Modified by bill mcdonald, 1:59 PM 4/28/2002]
Old Apr 28, 2002 | 06:36 PM
Allblownup's Avatar
Allblownup
Default Re: C4 supercharger problem advise needed (bill mcdonald)
How about a new fuel filter? Might be starving engine also as said before not enough gas in tank. Maybe net on intank fuel tank might have alot of crap. Hope this helps.
Old Apr 28, 2002 | 08:12 PM
snaketr's Avatar
snaketr
Default Re: C4 supercharger problem advise needed (Allblownup)
Make sure that the plastic sump in the tank has not come loose. This is what that is supposed to prevent.
Old Apr 28, 2002 | 09:47 PM
8388's Avatar
8388
St. Jude Donor '14
What their talking about doing here, is cut an opening at the lowest section of the tank and weld a smaller section with outlets, this would require an external pump and gravity would feed it. another alternative but it can get rather expensive is to modify the original tank with baffles, pretty much the same as an the oil pan designed for hard cornering and braking.
Some cars are more sensitive to fuel starvation than others, and this has to do with how the pump sits inside the tank. I was able to minimize the effect on my SC'd car when installing the bigger Bosh pump by positioning the pickup further back. But still its not safe to run a SC or TT car with less than 1/2 tank, if you plan to run it hard.
Old Apr 29, 2002 | 11:18 AM
RVY's Avatar
RVY
My good deed for the day. Been there, done that. As have many on this forum. The stock pump cant keep up with the T Rex./ Replace the stock unit . I prefer a Bosch pump. Basically a drop in installation. Others prefer another unit. Possibly an hours work. Your probably putting out about 405/410 rwhp. your air fuel ratio is probably 13.8-1. If in the future you go the 383/ 9-1 compression route, dual pumps/ lines should be a consideration.
PS--- Don't believe the fuel pressure gauge on the dyno unless the vehicle is under load.
Old Apr 29, 2002 | 04:51 PM
black bart's Avatar
black bart
Default Re: C4 supercharger problem advise needed (RVY)
I agree with RVY you have a fuel problem. I have two fuel pickup tubes and three fuel pumps on my car but the third pump is on a rpm switch and kicks in automatically at 4000 rpms if below that it is not needed. It takes a lot of fuel to make big power. :seeya
To C4 supercharger problem advise needed
