I have a 1984 Targa X-Fire that is very cranky. One moment it is running fine the next time I start it it barely runs at all. The next I start it, it runs fine. I've changed the O2 sensor, the throttle position sensor, the fuel filter, temp switch and cleaned the throttle body/injectors. The plugs and wires are good. There are no "idiot" lights or codes. I just got the car and I am a newbie to Vettes. Where should I check next? Thanks for the help.
From: One day you're a Comet...the next day you're dust... Arkansas
Originally Posted by jgwartist
The way I feel about it right now fecal works.
I was just kidding around I thought that was obvious because your spelling was so close to fecal. I really don't know what's wrong but two things worth considering are grounding and the ECM.
