Pop up head lights
Old Aug 8, 2011 | 08:21 PM
Charming's Avatar
Charming
Cruising
Default Pop up head lights
I have read so many posts that say installing the Bushing set that I purchased would take a few hours. Well I'm going on my 4th hour and I still can't seem to get the gear to separate from the Head light bracket, I have removed the head light assembly, thats on the bench the motor is seprate from the Gear
Ecklers said it is difficult to remove the large white gear from the shaft. I CALLED TO MAKE SURE THE WASHER IS NOT THREADED ON. Ecklers said not threaded on just pry the Gear and washer off,
I have pryed and think the whole fricking bracket is twisted. and I still can't remove the Gear., and the gear is still free wheeling so I'm stuck.
Old Aug 8, 2011 | 08:39 PM
oldalaskaman's Avatar
oldalaskaman
https://www.corvetteforum.com/techti...=156&TopicID=2
Old Aug 8, 2011 | 08:41 PM
oldalaskaman
http://web.archive.org/web/200402021...=259&TopicID=2
Old Aug 11, 2011 | 04:35 AM
Movnviolation's Avatar
Movnviolation
Just went through the same thing with my 89. The plastic gear would not lift out. It would turn freely but would not lift off the shaft. Finally said screw it and put a screw driver in and pried the gear up. It slid right off. The spacers were toast. Did both lights and they work great. The first unit took about four hours, but the second one took only about 40 minutes.
Good luck
Old Aug 11, 2011 | 11:56 AM
Charming's Avatar
Charming
Cruising
I'm glad every thing went well for you, I was unable to remove the gear.
Old Aug 11, 2011 | 12:12 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Please, their not pop-ups, they rotate, much cooler.
Old Aug 11, 2011 | 12:36 PM
littlesk8cracker's Avatar
littlesk8cracker
i did the same, pryed up with a screw driver. first one took me hour and a half, 2nd took maybe 20 minutes
To Pop up head lights
