Brake Sticking Left Front 1987
Old Aug 10, 2011 | 04:33 PM
Martha's Vineyard's Avatar
Martha's Vineyard
2nd Gear
Default Brake Sticking Left Front 1987
This seems to be a common problem and I have addressed the usual causes with no results. Replaced rubber hose, no change replaced caliper, no change and just replaced the master cylinder, no change. So now I'm lost. Any help would be appreciated.
Old Aug 10, 2011 | 04:44 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
ABS or pinched hard line
Old Aug 11, 2011 | 10:22 AM
383vett's Avatar
383vett
When you apply the brakes, does it pull hard to the left? When the front is raised, is the wheel hard to turn?
Old Aug 11, 2011 | 06:51 PM
Former Ford Boy's Avatar
Former Ford Boy
I had the exact same problem on my 87 a4, but on the right side. It turned out the be the ABS pump. I also replaced the brakes, calipers, hoses, etc. before concluding that the pump was at fault. I found a used one on eBay for 125.00 and replaced it myself.
Phillip
Old Oct 18, 2011 | 10:58 AM
barbedwiredave's Avatar
barbedwiredave
i am having the same problem, new calipers, new hoses. gonna have the system flushed and then replace abs pump. did you replace the pump then bleed the brakes to remove the air from the abs unit?
Old Oct 18, 2011 | 01:01 PM
yorkfitter's Avatar
yorkfitter
Had the same problem with my 86, replaced caliper and flexible brake line at wheel. It was the abs pump, did not want to spend money on new abs pump. Cut the metric ends off at pump and found sae inverted flare couplings and reconnected.
To Brake Sticking Left Front 1987
