Very Rough 89
Old Aug 11, 2011 | 07:39 AM
LT1 Rocker's Avatar
LT1 Rocker
Default Very Rough 89
One of those things that goes bump in the night apparently got to my vehicle while I was sleeping last nite.
I started it to drive to work this morning after it sat in the garage for a week and it shook, rattled and smoked. It has been running great up to today.
Its one of those situations that it is running so poorly that I don't even know where to start. Would condensation in the gas be the cause?
Your thoughts would be appreciated.
Old Aug 11, 2011 | 08:11 AM
WW7's Avatar
WW7
The only time something like that happened to me, it was because a mouse had chewed through ignition wires.. You can hook up a scanner and also check for codes.. You may also want to disconnect the battery cable for a few minites to reset the ecm, this will reset everything, sort of like rebooting your home computer when it loads wrong......Good Luck......WW
Old Aug 11, 2011 | 08:22 AM
Muffin's Avatar
Muffin
If it is running that bad fault codes are most likely set. Pull codes and post them here. "Resetting" the ECM will very likely not help.
Old Aug 11, 2011 | 09:13 AM
myfunz's Avatar
myfunz
I drive mine on the weekends only and never had a condensation problem from weekend to weekend, may be bad gas? I'd check fuel pressure at the rails first.
Old Aug 11, 2011 | 10:10 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old Aug 12, 2011 | 09:16 AM
LT1 Rocker's Avatar
LT1 Rocker
Default Update
I started the ole girl when I arrived home from work last night and she ran fine without any of the issues experienced that morning. I can only guess that she got up on the wrong side of the bed and was cranky.
Just for jollies I dumped some drygas in. Drove it to work today and it ran fine.
Go figure!
Thanks much for your feedback.
To Very Rough 89
