Pot hole = lost readings!
Old Aug 15, 2011 | 06:08 AM
Danjb25's Avatar
Danjb25
Default Pot hole = lost readings!
I drove over a pot hole on Saturday, it was filled with water. Now I am not getting any Oil temp or pressure readings, the speedometer only reads 0 and I am getting a Service Engine Soon light and Service ASR. Any idea whats wrong and what I could do to fix the problem?
Old Aug 15, 2011 | 08:07 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
Sounds like you have jolted the digital dash and broken something inside it. Could check the main connector is tight. Have to lower the steering wheel, take off a few screws and remove the dash fascia to get access to the connector. Otherwise remove the digital dash and send it for repair if it is not working.
