Rear body panel adhesive
Old Aug 16, 2011 | 08:43 PM
The Bus's Avatar
The Bus
Default Rear body panel adhesive
I've removed the lower rear body panel. I think it's called the rear bumper. It was bolted on. The upper section that mates with the rear window frame appears to be bonded together with panel adhesive. I need to remove that panel. Is there a adhesive softner??? OR how does it come apart????
Thanks for all info
Old Aug 16, 2011 | 10:44 PM
oldalaskaman's Avatar
oldalaskaman
heat gun , gently
Old Aug 16, 2011 | 11:36 PM
JackDidley's Avatar
JackDidley
I use a sharp putty knife. Just use it like a chisel.
Old Aug 17, 2011 | 01:10 AM
oldalaskaman
heat gun is much quicker, i've done it both ways
Old Aug 18, 2011 | 02:26 PM
pipe's Avatar
pipe
Don't forget to drill the small rivet out back near the gass door that holds the rear quarters together. Pipe
To Rear body panel adhesive
