Old Mar 6, 2015, 12:37 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension How-Tos
Print Wikipost
rear leaf spring replacement
Old Aug 18, 2011 | 04:42 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Default rear leaf spring replacement
Had the rear fiberglass leaf spring replaced 5 years ago and the new one just cracked. How much should labor be to replace it? It was done as a favor and it took all of 30 minutes last time. I'd do it myself but its not fun without a lift
Old Aug 18, 2011 | 06:50 AM
oldalaskaman's Avatar
oldalaskaman
its not hard to do, use a couple of jackstands, take one side at a time loose using a floor jack to release the tension, gently,four bolts at the center, reverse procedure to install the new one. good time to put new bushings in.
Old Aug 18, 2011 | 07:39 AM
rodj's Avatar
rodj
Pay attention to how the shims / spacers are positioned on the spring mount attached to diff housing BEFORE you remove the spring
Take pics
Old Aug 18, 2011 | 11:21 AM
radar502's Avatar
radar502
The rear not that big of a deal ..Jack stans work fine take tenison off spring will a this point just be hanging there .. Take out 4-bolts spring will fall on your head make sure head out of way..Easy fix..The front not so easy...
Old Aug 20, 2011 | 01:45 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Thanks for the info guys...I got lazy and took it to a Ford dealership with my own new spring and a real nice mechanic put it on in 30 minutes and charged me $40 for labor and inspected my car for free...so I gave the mechanic a $30 tip...
Old Aug 20, 2011 | 10:45 AM
radar502's Avatar
radar502
Cool, put this guy on your birthday list, My guy he has big vett shop $150,00 ea.. Good deal....Around here it cost $30 just to ride buy the Chevy ..place.. I thank they have a toll booth..LOL
Old Aug 20, 2011 | 11:50 AM
383vett's Avatar
383vett
A corvette in a Ford dealership? Did you take a picture?
Old Aug 21, 2011 | 06:30 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Picture?
Well... any good mechanic can work on Chevys or
Fords and actually as much as I have owned Chevys for the past 5 decades, Ford does have some better ideas...and btw...there is nothing wrong with Mustangs...I just like Vettes more
Old Aug 21, 2011 | 02:34 PM
leesvet's Avatar
leesvet
Sacrilege ......
To rear leaf spring replacement
