ecm troubles?
Old Aug 21, 2011 | 02:14 PM
aDigitalPhantom's Avatar
aDigitalPhantom
Default ecm troubles?
Sometimes when i am driving my vette the sys/security will flash, other times it will be the service asr/ses light that is on, and sometime both. When I check for error codes (paper clip) about 50% of time I get nothing the other 50% I get Err from the ECM. The CCM also had codes 41, 54, and 72.
Now for what i have done.
I turned off vats in the ECM.
I checked pin m on the dlc connector for a short, it apears to be shorted to B+ when the ECM is pluged in.
If I need to check anything else let me know as I am not sure this is the ECM.
Old Aug 21, 2011 | 02:31 PM
leesvet's Avatar
leesvet
I'd certainly go thru the harness grounds and power sources, all near the battery.
Next, look hard at the firewall bulkhead seal for damaged wire entering the cabin.
Old Aug 21, 2011 | 07:09 PM
aDigitalPhantom
All the grounds i could see look fine. With the computer unhooked pin M is no longer shorted to B+. Also if i tap the computer in a specific spot the car dies.
Old Aug 30, 2011 | 08:33 PM
aDigitalPhantom
the only thing i know for sure about the problem is it is temperature related. I have replaced the battery and ecm at this point.
no change.
Few questions
1. what happens if the injector driver gets overloaded?
2. what are the ohm specs for the injectors on a 1993 corvette
3. what does the ccm do/control
4. What is needed to put in a TPI ECM/Distributor and remove the LT1 ECM, I know i will loose the factory speedo/gauges
5. what about 24x conversion and remove the LT1 ECM.
6. if i decide to use 2 or 3 and not fix as is can i remove the ccm?
cold ohms
8=~13.8 7=~14.5
6=~14.5 5=~14.5
4=~14.5 3=~14.5
2=~14.5 1=~14.5
Old Aug 30, 2011 | 09:50 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
If it hasn't changed from 89 to 94, sys/security flashes when the door is open. It can flash when close -- IF -- the door switch is misadjusted or problematic. I believe the door switch near the latch is the one(s) you should check. The switch at the front of the jam controls the courtesy lights.
These switches are on both doors.
Since I don't have the ASR option, I can't help with that.
Old Aug 30, 2011 | 10:49 PM
aDigitalPhantom
I forgot to add, that yesterday I found that ccm fuse #2 was bad so I replaced it.
also
I now know it is pretty much.
after about 35-50 minutes of driving the Service ASR/SES is on and Security Light flashes. The SYS light is probably also flashing (not sure there aftermarket radio, need to add resitors). Last time this happened I put a bag of ice on the computer for a while and let it chill but the lights did not turn off until I disconnected the battery. If I disconnected an reconnect the battery without putting ice on the computer most of the time it will restart but the lights will still be on.
Old Aug 31, 2011 | 12:01 PM
aDigitalPhantom
when the digital temp gauge read ~120
the ohms were
8~20 7~60
6~20 5~60
4~30 3~60
2~30 1~80
that does not seem right.
also what happens if the injector driver overloads?
Old Aug 31, 2011 | 03:24 PM
GREGGPENN's Avatar
GREGGPENN
the ohms were
8~20 7~60
6~20 5~60
4~30 3~60
2~30 1~80
Are you pulling the injector plugs and measuring the contacts in the plug? For the injectors themselves, you measure the contacts on the injector.
That said, I would be suspicious of injector connector readings with that much disparity.
Old Sep 1, 2011 | 05:07 PM
aDigitalPhantom
I think I found the real reason behind all of the gremlins. the charging system. when I was driving it today I had a multimeter hooked up to the cigarette lighter and it got up to 17.4 volts before I got home. This is with a new reman alternator. Ok don't ask me why I checked the charging system but i did and replaced the alternator the old one on a test bench was at 19.5 volts.
Any ideas as to why an alternator would do that?
Old Sep 1, 2011 | 06:37 PM
GREGGPENN's Avatar
GREGGPENN
Well, I'm not a charging system expert, but I thought the voltage regulator was supposed to keep the voltage from peaking (above 14.4V). (I'm not sure it regulates min voltage though.) On our cars, the regulator may be in the alternator.
Without a properly functioning regulator, you'd see external and internal lights getting brighter/dimmer.
Injector pulse width is also based on (and is adjusted by) a table dictating how they should react vs Voltage. Systems without a functioning regulator could because a bit more irratically rollling down the road...or idling. Possibly starting too.
Old Sep 2, 2011 | 12:11 AM
87 vette 81 big girl's Avatar
Defective voltage regulator in the GM CS130 alternator.
I have seen it prior too.
Old Sep 2, 2011 | 03:40 PM
aDigitalPhantom
I think my car is possessed. It was fine all day yesterday after changing alternator, but today it is back at it, only not dying. I got a dtc for the first time (yay?) it was #43. I also ask a different mechanic about it and he says optispark.
Old Sep 2, 2011 | 03:53 PM
STL94LT1's Avatar
STL94LT1
Looks like you are in desperate need of a new mechanic. That is not an optispark code.
Old Sep 2, 2011 | 04:23 PM
aDigitalPhantom
Did not think it was so i did not leave it there, also the code is intermittent.
Old Sep 2, 2011 | 05:29 PM
aDigitalPhantom
You're gonna love this, but I just found out the negative battery cable has a short in it. So I will replace that and see what happens.
Old Sep 2, 2011 | 06:18 PM
GREGGPENN's Avatar
GREGGPENN
Having a "short" in a negative ground isn't the same as a positive line. You could say it's double-grounded!
OTOH, if there's a loose connection, that's not (technically) a short.
Old Sep 3, 2011 | 12:27 AM
aDigitalPhantom
true. I replaced the loose battery cable end and and drove it about 1-2 miles and now it won't start.
can a memcal fail and still have the prom be good? I have a Moates burn 2, and some SST27SF512 chips that read fine in the burn 2 same thing i programed on them. When i turn the key on the fans turn on and there are a bunch of relays clicking.
To ecm troubles?
