Do these numbers look OK?
Old Aug 21, 2011 | 05:08 PM
SouthernSon's Avatar
SouthernSon
Default Do these numbers look OK?
engine cruising at operating temperature - catalytic convertor temp 1450 degrees.
ignition timing floating throttle - around 42 degrees
WOT - 2k rpm - drops to 27 degrees
WOT - 2.5k rpm - drop to 35 degrees
WOT - 3k rpm - drop to 36 degrees
I do get knock retard of 4 degrees 2k and up w/WOT w/ a/c on.
normal????
Old Aug 21, 2011 | 09:13 PM
thearborbarber's Avatar
thearborbarber
Those numbers are pretty close to my last WOT data log. The advance within plus or minus 1 or 2 degrees and the retard about a 2 degrees less than yours.
