Master Cylinder Warning Switch
Old Aug 21, 2011 | 08:19 PM
jhimer's Avatar
jhimer
Default Master Cylinder Warning Switch
!984 has been sitting for 10 years. I have the engine running with replacement of the fuel tank, fuel pump, fuel filter,Crossfire injectors,spark plugs,cap and rotor. Before I move it I would like to have brakes. Replacing Master cylinder and The warning switch came apart. I have the terminals, spring and the small pointed end cap. This is hard to find locally. Can this piece be replaced as is and work then replaced later?
John
Old Aug 21, 2011 | 09:01 PM
oldalaskaman's Avatar
oldalaskaman
napa has them, if you just need to run the car , you can plug the hole with the right thread plug. hope this helps
Old Aug 21, 2011 | 09:03 PM
leesvet's Avatar
leesvet
just plug it. Its just the warning light.....You can order from NAPA or some of the catalog stores carry them.
Old Aug 22, 2011 | 01:40 PM
aklim's Avatar
aklim
Isn't that what warns you that you are low on brake fluid which can be helpful if you have a leak?
Old Jan 27, 2013 | 11:51 AM
EDQ's Avatar
EDQ
What thread size
Old Jan 28, 2013 | 02:27 AM
Cliff Harris's Avatar
Cliff Harris
The warning switch port has no fluid in it (unless you have an internal leak). You can just leave it open. Probably best to cover the hole with tape or something to keep junk out of it.
To Master Cylinder Warning Switch
