Stalling Question?
Old Apr 29, 2002 | 11:33 PM
CG77VETTE's Avatar
CG77VETTE
Default Stalling Question?
I just started having a stalling problem. When the engine temperature goes above 200 degrees, the engine runs at 400 to 500 rpm at idle in drive. If I am sitting in traffic the engine stalls if I don't keep the rpm's up by depressing the gas pedal a bit. Any ideas on what could be causing this would be most appreciated. BTW I have an early '86 iron head mostly stock with 102,000 miles on the original engine. Thanks in advance.
Old Apr 30, 2002 | 09:24 AM
CG77VETTE's Avatar
CG77VETTE
Default Re: Stalling Question? (CG77VETTE)
ttt
Old Apr 30, 2002 | 09:36 AM
Oh My's Avatar
Oh My
Try pulling out your idle air control motor and cleaning it out. Also inspect over the TPS for proper voltage, which i believe is .67 . And as always, check for those annonying vacuum leaks. Good luck
Old Apr 30, 2002 | 10:30 AM
PTz-92-LT1's Avatar
PTz-92-LT1
The idle air control would be my first guess.
Old Apr 30, 2002 | 10:36 AM
ittlfly's Avatar
ittlfly
Default Re: Stalling Question? (PTz-92-LT1)
Me too.
To Stalling Question?
