Superram + Nitrous question
Old Apr 30, 2002 | 10:15 AM
AS84's Avatar
AS84
Default Superram + Nitrous question
Has anybody tried a throttle body plate system on their superram setup? I found a good deal on one but from the way the intake is designed I can see a few cylinders getting less nitrous than others, particularly on the drivers side bank. I was planning a fogger system, but I found a good deal on this plate. What do you think?
Old Apr 30, 2002 | 11:35 AM
scorp508's Avatar
scorp508
L98Terror does with luck so far. The best way to go though is direct port or a dry system. There have been many many cases with the plate getting blown off because the plenum becomes a HUGE combustion chamber.
Old Apr 30, 2002 | 01:47 PM
black_89_vette's Avatar
black_89_vette
Default Re: (scorp508)
I'm in the process of installing a TNT 150 shot on my super ram as we speak. My mechanic had to fabricate a few brackets and re-position the nitrous nozzles, due to hood clearance. The TNT kit I bought isn't designed for a super ram (communication error by me there with the vendor...oh well) so my mechanic has designed a bracket holding both solenoids and mounting the nozzles in from the side instead of the top (not enough hood clearance from the top). We have it designed so that from the side it doesn't interfere with the throttle linkage. I hope to get it back in a few days and by the weekend, I'll be needing to get the bottle filled again :D
To Superram + Nitrous question
