C4 Mild - Inexpensive Upgrades
Old Jan 17, 2013 | 12:35 PM
  #41
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Originally Posted by ScaryFast
Camshaft ($300)
Headers ($500 - 800)
1.6 ratio roller rockers ($150)
Exhaust (varies)
Porting heads ($1000)
$300 does not get you 35 HP. Real HP is not free, but it's not extremely expensive, etiher. My LT1 made 414 to the wheels following this recipe, which equates to 480 HP at the crank assuming 15% drivetrain loss. Guys like Tom400CFI are where I got my information.
This is from on old post which a search would easily uncover:
Recipe for 425 to 450 CRANK HP:
Corvette 350 LT1 with flattop pistons. (Stock components will work)
LT1 Alum. Heads that flow over 260cfm/intake, 190 cfm/exhaust. (Pretty easy to achieve through CNC or hand porting by a pro)
1.75" Full length headers with dual 2.5" exhaust and hi-flow mufflers.
Relatively large camshaft with at least 236 degrees of duration @ .050" and .550" to .585" lift, depending on the ported head's limit. (With no emissions and decent exhaust this can be a single pattern cam with 110 or 112 degree LSA)
52mm or larger throttle body with modified air filter assembly.
24lb to 30lb injectors, depending on who programs/tunes your PROM.
.029" headgasket to get 10.75-11.0:1 compression, depending on final combustion chamber size after head porting/milling.
MSD 6A or 'bigger' and a full-size coil for top end spark energy.
Electric waterpump and an aluminum flywheel will also help the 'bottom line'.
Comp Cams Pro Magnum Roller Rockers and measure for custom length pushrods.
No aftermarket filter setup makes any gains on a stock or slightly modified engine. Cam and headers will be tremendous all for less than $1K (even lower depending on header type).
Old Jan 17, 2013 | 02:34 PM
  #42
ch@0s's Avatar
ch@0s
Scary.. just tell em to drop an LS in there then the Claw makes a difference.
Old Jan 17, 2013 | 02:51 PM
  #43
QCVette's Avatar
QCVette
Active Streak: 90 Days
I agree cam and headers are usually the best bang for the buck to increase power.
The higher ratio rockers are an easy and relatively inexpensive mod that helps a little by slightly increasing the cam. I have done that on a couple too. If you are changing cams though you may be able to find the profile you want without the added ratio.
I have also heard that the LT1 stock manifolds and exhaust are pretty good. The gains from headers will show more effect the wilder the engine is.
Heads may be the constraint to making a lot more power. A good porting or aftermarket like the AFR's can really do good, but head work/aftermarket heads can be expensive.
Old Jan 17, 2013 | 04:09 PM
  #44
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Local crew member was having the same discussion about his yellow 93 vert. Looked nice but was not real exciting to drive.
Solved the problem by purchasing a used yellow C5 Z06 from Berger Chevy in Grand Rapids.
Now you can't wipe the smile off his face. And, he kept the vert for cruising. Win-win.
Old Jan 17, 2013 | 09:02 PM
  #45
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by NCBLACKC4
Ok? help us out, what can we buy for the same $$$ that "would buy something that would show substantial, measurable, and repeatable gains."
If you read my post above, you would already see that I recommended a cam for the same amount of money.
Scaryfast did an excellent job outlining gains for cost.
If you want an intake for looks, I can't argue with that.
Old Jan 18, 2013 | 03:13 AM
  #46
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Doing the work myself got me 426rwhp and 396rwtq and cost about $5k.
Dyno tune, Crane Gold 1.6RR, SLP claw, AFR 195 heads, 11.0:1 compression, LT4 intake, LPE 219, Electric waterpump, LTCC, EM Headers, Magnaflow 3"cats and X-pipe, Borla mufflers and AC delete with a stock short block.
Old Jan 18, 2013 | 09:50 AM
  #47
ScaryFast's Avatar
ScaryFast
Dude you have no idea what's happened to me. I've become obsessed, I now have 4 LSx's. I am now looking for cars to put them in. I have the magic LS6 that I put into the C4 last year, I have a 24k miles LS2 I picked up with a friend, we also have an LS6 ASA motor that's going into something...plus the LS2 in my C6 is tired so it needs replacement. I am going on that show "Hoarders" because of this new fixation.
DId you ever figure out your tranny issues?
Old Jan 18, 2013 | 09:53 AM
  #48
ScaryFast's Avatar
ScaryFast
I guess I should have been more clear in my post on page 2. Each of those things on the list can provide some gain, but you really have to put it together to get big numbers. Just a cam will give a nice "bang for the buck" improvement, but if you don't also improve your cars breathing you're only getting half of what you could. Head porting and better exhaust finish the deal. The other stuff is mostly support, like injectors, roller rockers, etc. to allow the cam to do it's work.
Old Jan 18, 2013 | 10:32 AM
  #49
Kubs's Avatar
Kubs
Tell you what. I'll loan you my car to be the "something" one of those go into!
Old Jan 18, 2013 | 10:49 AM
  #50
ScaryFast's Avatar
ScaryFast
Sure, I'm doing LSx conversions for $10k.
Old Jan 18, 2013 | 01:55 PM
  #51
ch@0s's Avatar
ch@0s
Same thing happened to me, my wife had to stop me from buying a 60k LS1 from a friend. I figure my next LS swap will be another C4, Miata or Monte SS.
Yes I did, I had the trans and the converter rebuilt. They are ready to go back in as soon as I get off my butt. We have a 4 month old and I get like 4-5 hrs sleep and have been working 10hr days
