Hurst Shifter Question
Old Apr 30, 2002 | 10:41 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Hurst Shifter Question
Since the Hurst Shifter does not have a lockout ring for reverse and is similar to the later stock shifters. If i were to install one on my 89 with the lock out ring. How is the shifter set-up to deter the ease from shifting in reverse?
Old Apr 30, 2002 | 10:48 AM
sputnick's Avatar
sputnick
Default Re: Hurst Shifter Question (-=Jeff=-)
The tranny in my car (93)will not let you in reverse unless you are under 5mph. You can feel the reverse gate through the stick. A detent, if you will. The only problem you may have is moving past the 5 gate into the top of reverse. Just alter your technique. I did this about 3 times. Now 5 is just as easy as the rest.
Old Apr 30, 2002 | 01:56 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: Hurst Shifter Question (sputnick)
It isn't a problem. I've only missed the gate and hit reverse once, and was skipping gears. You will love the Hurst awesome feeling shifter. :yesnod:
Old Apr 30, 2002 | 06:28 PM
bogus's Avatar
bogus
reverse is not syncronized... FWIW, reverse is nearly impossible to engage at any speed above moving.
the gears just won't engage... period.
oh, the Hurst RULES!!!!!!! :cool: :cool: :cool:
[Modified by bogus, 5:29 PM 4/30/2002]
Old Apr 30, 2002 | 08:10 PM
pablocruise's Avatar
pablocruise
It takes some firm pressure on mine, to get into reverse. The tranny is out of the car, but it still takes some firmness to get it into reverse and not 6th. ***oooops, correction, that was before this got welded: I took the Hurst back out for the fix but haven't put it back in.
As far as price, I found Speed Demon motorsports and Summit tied for lowest at $129.00.
The shifts feel real nice and solid. Almost clunky, but in a good way.
[Modified by 89 Paul in Cal, 4:11 PM 4/30/2002]
To Hurst Shifter Question
