1989 Corvette Gas Type?
Old Aug 29, 2011 | 08:25 PM
CAmaninacan's Avatar
CAmaninacan
Default 1989 Corvette Gas Type?
Just got my second corvette, and i learned something new, am i suppose to put premium in it? My 90 i put the cheap gas in? Which gas do you guys prefer. Thanks.
Old Aug 29, 2011 | 09:47 PM
oldalaskaman's Avatar
oldalaskaman
use the cheap unless it pings.
Old Aug 29, 2011 | 10:03 PM
JackDidley's Avatar
JackDidley
If you use cheap gas it will ping.
Old Aug 29, 2011 | 10:22 PM
oldalaskaman
mine dont
Old Aug 29, 2011 | 10:52 PM
87 vette 81 big girl's Avatar
Originally Posted by oldalaskaman
mine dont
What brand of gasoline do you buy & use in your 87 Bob ?
I have been told that all gasoline comes from the same vendor or wholesaler in the past.
Beginning to question Shell & B.P gasoline myself.
Here in Illinois there are Casey General stores all over outside of Chicago area.
At times I have filled my 87 up with Casey store 89 octane gasoline(highest octane they carry & sell) & it seems to run A-OK with no pinging at WOT.
Next day I fill up with Shell 93 Gas & it seems to run sluggish sometimes.
Slight pinging present too for 1 or 2 seconds & there disappears,
ESC knock sensor kicked in & retarded ignition timing.
Next time I buy Shell gasoline elsewhere,
A- OK again.
Old Aug 30, 2011 | 12:18 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
EFI cars have knock sensors as part of their design. When your motor even THINKS about pinging, it will pull timing to prevent it. (The KS can "hear" knocking before you can.) Occasionally, you'll get knocking if you install platinum plugs. (They run hotter and can be a source of detonation). Some shops now recommend AGAISNT platinum plugs in C4's.
That said, you can run lower octane (aka cheap) gasoline. By doing so, I'll guarantee your knock sensor will be more active and you'll be missing some power. If power isn't that important, run the cheap gas. As long as your ESC is in working order, you won't blow up the engine. It can pull anywhere from 5 to 20-degrees of timing depending on what RPM range you're in.
If you run cheap (lower octane) gasoline, I bet you could be missing up to 10% of peak power levels.
Old Aug 30, 2011 | 12:23 AM
GREGGPENN's Avatar
GREGGPENN
Several years ago, the number of brands/refineries was around 5. IOW, there were about 5 major suppliers for gasoline. Maybe that's changed, maybe not.
My guess is there's one for each of the major oil companies. And, that the smaller guys (including convience stores) buy from the big boys. Of course, they'd get the mega-gallon quantity discount which probably enables them to undercut the brand-name stations.
OTOH, I've never noticed the top-tier 92-93 octanes at the cheaper places. Shell, BP and Philips 66 are the only ones around here that carry it.
BTW: The reason why you'll rarely hear cheaper gas ping was addressed in my post above.
Old Aug 30, 2011 | 01:03 AM
oldalaskaman
I actually buy the cheapest, usually arco, thrifty, etc. The bad old days of them watering the tanks are pretty much over and if you have ever looked at the tank farm loading racks, you will see trucks from 76, arco, shell,etc, but you will also see unmarked trucks. Those are delivering the same fuel to the independents. years and years ago, when I would put on a load of fuel for an independent, the rule was that you left it 500 gallons light, pull around to the water rack and top it off with water, that way it could shake and mix in prior to dumping it at the station. I've pulled up to stations and the owner would be standing at the fill with a garden hose . Thats all gone, thankfully, there's alot of oversight now days that we didnt have back then, and theres are water sensors at the bottom of most of the station tanks that set off alarms with moisture. In smaller markets its still possible to get a load of bad gas, and if you think you've been given some, there's a number on each pump that you can call , and they will come out and test the tanks, if you've saved your reciept, refunds are available. sorry , a bit to wordy.
Old Aug 30, 2011 | 02:45 AM
GREGGPENN's Avatar
GREGGPENN
By "cheap", I mean lower octane than premium. The manual states premium as a requirement (91 octane I believe). And, their timing tables are coded accordingly.
Old Aug 30, 2011 | 08:09 AM
bjankuski's Avatar
bjankuski
For max power with these cars you want high octane.
Old Aug 30, 2011 | 08:56 AM
Flame Red's Avatar
Flame Red
Covered a gazzillions times. All gas comes in at the same terminal pipeline. Different vendors will add additives at the depot unque to their brand. Chevron adds Techroline (sp?). Others do similiar. That is what makes a brand.
You can run it with cheap gas, but you won't be getting max performance. The knock sensor will limit you.
BTW - you call can thank the Gooberment for adding Ethanol which will decrease your milage significantly. You can also thank the EPA for boutique blends that raise the cost of gasoline since the refiners have to produce hundreds of different formulas.
Old Aug 30, 2011 | 09:58 AM
oldalaskaman
amen, with the upgrades learned on this site for vettes, many thanks to all of you, I get 25-27mpg and never stick my foot in it......anymore....well not all the way...ok, ok, not as much...peak hp not an issue.
Old Aug 30, 2011 | 12:54 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
The 1989 owners manual says use 91 octane.
Old Aug 30, 2011 | 12:55 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I can use Regular on my LT1. My LT4 requires, needs and must use 91 or higher.
Old Aug 30, 2011 | 01:20 PM
JackDidley's Avatar
JackDidley
If you datalog your car, you may see that it knocks its *** off before the ECM pulls enough timing to stop it. YMMV.
Old Aug 30, 2011 | 11:23 PM
Those SOB's.....................LOL
You have confirmed 20 years of my own suspicion Bob.
Here in Illinois 100 miles south of Chicago>>>>>>>>>
There is not a single Non- white turbine hat wearing gas station owner.
Just in hickville.
My late buddie threatened to kill all of them when alive several times.
Had to pick him up out of jail a few times.
LOL.
64 years old too.
They allways smile ear to ear when I drive off.
My Red 87 C4 included.
mother f****@#s.
Old Aug 31, 2011 | 08:40 AM
WW7's Avatar
WW7
My 89 owners manual says this. Straight from the book...WW
Old Sep 23, 2011 | 12:44 PM
themadvetter's Avatar
themadvetter
I made the mistake of using 89 since it was the same price as 87. It just didnt have the same feel so i have been using bp 93 ever since but its hard to find... i found a place called www.octanelocator.com that has a few stations listed around the country but not enough near me for a road trip....
Old Sep 23, 2011 | 01:36 PM
navy_vette's Avatar
navy_vette
Ya'll complain about gas
I'm in Italy. I always feel like I should be putting water remover every time I fill up.
To 1989 Corvette Gas Type?
