whats the problem?
Old Sep 1, 2011 | 11:11 PM
flyby77's Avatar
flyby77
1st Gear
Default whats the problem?
Hey Guy's, New to the forum and hoping yall could help me and my buddy find out what going on with his 89 vet .
Symptoms Are
  • From a full throttle take off car will feel like it is missing and will slowly pick up speed
  • During cruising speeds, the car will feel as if it is missing, having to shift in neutral and rev it up at time to keep it going
  • From a MPH roll to full throttle car will bog but if you easy into the throttle car will pick up speed slowly
We have only got one code that stated the car was in a lean condition
We have replaced / installed new
  • Plugs / Wires
  • Distributor cap and button
  • Fuel pump and strainer and filter
  • Maf and relays
If there is any thing that any one can think of for us to check or if anyone has had this problem pleas let me know, ANY HELP WILL BE WILL BE APPRECIATED!!!
Old Sep 1, 2011 | 11:34 PM
87 vette 81 big girl's Avatar
After verifying you have the correct fuel pressure of 41-47 PSI with engine running & vacuum line removed from the fuel pressure regulator,
Its time to Impedance test all 8 fuel injectors.
All injectors should test within 1 ohm of each other.
There are GM Multec series fuel injectors factory installed in you 1989 Corvette.
They are know to be incompatible long term with today's E10, ethanol enhanced gasoline.
The Alcohol breaks down the fuel injector internal Bobbitt coil winding enamel insulation.
If so,
Resistance - impedance test will show it with a Digital multimeter set to OHM's scale.
Around 12 ohms is correct from my memory tonight for your 1989 C4 Multec fuel injectors.
BR
Old Sep 1, 2011 | 11:35 PM
leesvet's Avatar
leesvet
ck Cats....low ign voltage inj spray.... EGR stuck
To whats the problem?
