3-4 seconds and dies
Old Sep 5, 2011 | 03:44 PM
joe paco's Avatar
joe paco
Originally Posted by lgaff
Well, its not the IAC......replaced and still the same issue. I took a test light to the injector harness there is power there with the key on....
Any thoughts? not sure were shraeder valve is on the Callaway, tweaked the stock rail..
I am getting a spark signal with a test light on plug wire #1....
hmmmmmmm
I would try the items suggested in post 6. what you got to lose?
the book says to look for blinking light cranking. first, disconnect all inj harnesses, connect test light to one harness plug each side. if blinking then one route, not blinking, another.
I think with spark you have to have tach readings, so ref pulses from distr to fire injectors, but watch the tach when cranking anyway.
Old Sep 5, 2011 | 04:11 PM
lgaff's Avatar
lgaff
2022 Corvette of the Year Winner -- Modified
2021 C4 of the Year - Modified Winner
have 40lbs of pressure at the rail. Did not start it up as had cap off
Old Sep 5, 2011 | 04:17 PM
lgaff's Avatar
lgaff
I show oil pressure at the dash, which one shut down the injectors?
Old Sep 5, 2011 | 04:20 PM
lgaff's Avatar
lgaff
or are you saying you think its the wiring? If its a short would I have any power showing to them at all?
Old Sep 5, 2011 | 04:21 PM
joe paco's Avatar
joe paco
you wern't responding to my last post, were you? this isn't a fuel issue, seems to me. more likely an ECM or injector shorting issue, possibly TPS or MAf sensor. the clue is the short run time. a full fuel rail will run much longer.
if you remove fuses, you "short cut" eliminating one bank of injectors.
joe
Old Sep 5, 2011 | 04:26 PM
joe paco's Avatar
joe paco
lg, it would help to know to whom you are addressing your posts.
if to me, FORGET the oil pressure switch info. I don't have a 87 FSM but the 91 uses the oil switch as BACKUP, in the words of GM. most likley the earlier ones did too. besides the dash info is not the same switch.
if there is a short in the injectors or wiring, yes, the ecm shuts down inj drivers, sometimes after the first squirt.
*** backup to fuel pump, not to FP relay, direct to pump
Old Sep 5, 2011 | 04:36 PM
joe paco's Avatar
joe paco
I'm just folowing the fsm, dude, never experienced it but others have.
fsm has one whole section on checking voltage to injectors and cheking for a short in the grn or blu circuits. chart a-3 page 2.
Old Sep 5, 2011 | 05:41 PM
87 vette 81 big girl's Avatar
Just to ask,
Are You sure the Mass Air Flow Sensor is firmly plugged in on 1987 Callaway TT ?
I have photos of the '87 TT & they use a MAF like my standard '87 Vert.
My car just about refuses to start if the MAF connector is left unplugged.
Another time my car died & refused to restart.
Start for 3- 4 seconds like yours & then just die.
I wiggled the MAF connector & my car fired right up.
Cleaned the connector & MAF sensor connector pins with fine 600 grit sandpaper.
Light coat of silicone dielectric grease applied with a "Q" tip on the terminals afterwards.
No Problems since.
Fires up easily every time.
Came up in the past here on C4 that the MAF sensor is not used at all for engine starting purposes.
But I beg to differ on my 1987 Vert.
I can hook up my Snap On Scanner & watch the MAF sensor start working as soon as the key- engine is cranked & Grams per second counts (3-6 grams/ sec) while the engine is rotating over with Delco 10 MT starter motor.
Also learned the last night the TOP C4 computer software experts are far from cracking all programs put in by the original group of C4 engineers.
ASC2 software programming ?
I had that in College Electronics for 2 years.
Drove me crazy.
Why I still hate computers half the time.
But I am caving in finally 20 + years later.
Brian
Old Sep 5, 2011 | 06:27 PM
lgaff's Avatar
lgaff
ign module tested bad
Old Sep 5, 2011 | 06:58 PM
joe paco's Avatar
joe paco
I understand that the ICM is bad, but to clarify this post, yes, you can have one side of the inj harness terminal check good and no light on the other side -either open or shorted. I think it depends on how the harnesses were checked, whether looking for a blinking light while cranking or simply probing one side terminal to ground.
per chart a-3, you can get a blinking light, no light, or a steady light when checking.
the charts for "no start" and "start but immediately dies" do not mention an intermittent ICM, but I suppose it can happen. cross your fingers....
at least we can conclude that it is not the oil switch, I reckon .
joe
Old Sep 5, 2011 | 08:30 PM
KOOL.
That took a crap on my car too,
the original Ignition Module about in summer of 2008.
Old Sep 5, 2011 | 09:03 PM
lgaff's Avatar
lgaff
I am still getting codes 42 and 34 through an SES...I am also guessing my spark plugs are toasted from trying to start the car so many times
Old Sep 5, 2011 | 09:31 PM
  #33
stoydido's Avatar
stoydido
I gather that the engine is normal otherwise? the 34 may be part of the original problem, which is MAP, as you know. you can unplug it and the ecm should adjust. if it improves, the sensor or circuit is suspect.
not sure you can damage a plug by trying to start it. that does not compare to firing under pressures. is the est bypass connected secure?
add: "Still" getting codes? I thought there were no codes initially...the icam will not set a code,of course, but the MAP would have.
Old Sep 5, 2011 | 09:37 PM
  #34
Turn the headlights on & leave them on.
Disconnect the Negative battery cable.
Leave it unhooked for about 5 minutes.
Reconnect the Negative battery cable.
Shut off your headlights.
Start your 1987 Callaway TT without touching the gas pedal & let idle & warm up fully till the coolant main fan turns on & back off on its own normal.
Might take a while to warm up fully to 195F- 205F water temp tonight here in Illinois.
Around 55- 60 F outside down by here in Peoria, IL.
Drive your Corvette afterwards normal & see if the code(s) come back or not.
False codes can be triggered by ignition module total failures.
Going for late night ride in my 87 Vert.
Have some fun on the backroads & highways here.
Brian
Old Sep 5, 2011 | 10:11 PM
  #35
lgaff's Avatar
lgaff
I only had the code 12 prior to the start up, I will check the est I was playing with alot trying to trace down the issue. More to come...wifey said enough car time today and was done about 4-5pm
Thanks everyone for the help
Old Sep 5, 2011 | 10:15 PM
  #36
My wifey passed out asleep on the couch with my baby boy Nick.
Vette checks out A- Ok & fully warmed up.
My fun time now..........waited alll weekend for my fun thrill ride.
Have fun too.
Old Sep 6, 2011 | 09:22 PM
  #37
lgaff's Avatar
lgaff
Noooooooooooooo......back to were I started....runs 3-4 secs and dies. Ignition module tested as bad, replaced, but problem still lingers....maybe at this point plugs may be fouled.
To 3-4 seconds and dies
Old Sep 7, 2011 | 05:58 AM
  #38
If I would have known,
I would have stopped by with some of my own diagnostic equipment on hand.
I took my late night car ride to Chicago land late Monday night.
Hauled azz up there on the back roads.
Stopped by a few buds houses that are race crazy like me.
Then hauled azz home for more fun.
Love cruising at over 120 mph for 40 to 50 miles at a time.
Paid for it yesterday at work though.
Was tired all day.
Smiling this morning though
Old Sep 7, 2011 | 08:20 AM
  #39
joe paco's Avatar
joe paco
I feel the dejection, but am not surprised. icm tuned to shut down at 3-4 secs? does not sound likely.
plugs are not the problem.
go back to post 6 or so, check for shorted wires or injector. the second clue was "wiggled wires, started."
wooohoooooo!
again, the fsm covers this in 4-6 pages of analyses.
Last edited by joe paco; Sep 7, 2011 at 08:23 AM. Reason: ***add also check post 30 or relevent pages in fsm on how to verify inj harness.........
Old Sep 7, 2011 | 08:14 PM
  #40
lgaff's Avatar
lgaff
I pulled fuse for FI 1, car runs for 8 seconds and dies, pulled for FI2 and car stalls at 3-4.
I see 200 rpm on tach when cranking; which means ign module is working correct?
I guess next it to test pulse on each FI with a noid light?
